Run a power wire from engine bay through firewall
Old May 9, 2012 | 04:10 PM
tho2k's Avatar
3rd Gear
I have 2012 Acura RDX and I need to run couple wire from battery in engine bay through firewall. I did google around but couldn't any solution.. I need some help! Thank
Old May 10, 2012 | 12:22 AM
BigHatch's Avatar
not an SUV ...a Big Hatch
forget google. actually look under the dash...see where the rest of the wires are going. Use the same hole.
Old May 10, 2012 | 06:49 AM
DRR98's Avatar
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Zoom to 200% look at # 36
System Name / Component : FRONT BULKHEAD - DASHBOARD
RETURN TO CHOOSING A SYSTEM / COMPONENT FOR : RDX
Old May 11, 2012 | 02:46 PM
tho2k's Avatar
3rd Gear
Thumbs up
Thank All. Finally I found it..
Old May 11, 2012 | 10:55 PM
wspy's Avatar
2008 Acura RDX
Which hole did you find to use?
Old Jun 28, 2012 | 03:20 AM
Kaze66218's Avatar
Copy cat shinobi
I fed a 4awg wire thru the driverside footwell and bulkhead where the main engine/cabin harness grommet is located.
That is prolly the best bet.
Feb 25, 2020 09:57 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
Caddy
1G RDX (2007-2012)
Sep 18, 2015 12:44 PM
jblessing
Wash & Wax
Sep 17, 2015 09:28 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
