Remote Wire for Amp
Old Jun 11, 2013 | 11:58 AM
user65's Avatar
Remote Wire for Amp
I've read through a lot of the install write ups in this section, but one thing I couldn't find was a straight forward explanation of where the remote wire is ran from. I saw someone do it directly to the fuse, which looks ghetto and probably isn't good practice. I've added a kicker shallow mount to replace the factory sub, and now I'm going to add an amp with a lineout converter.
I've got a good understanding of everything except the remote wire. Do I need to run this to the back of the headunit, or is there somewhere else I can tap into, that's not the fuse. Am I correct in assuming it's not wise to hook it up to the fuse?
Side question on the lineout converter - it has 4 wires, right+ right-, left+ left-. I was assuming I'd just hook up r+ and l+ to the posi speaker wire and r- and l- to the negative speaker wire. Is this correct? I'm assuming the sub handles both left and right channels.
Old Jun 12, 2013 | 07:42 AM
wspy's Avatar
2008 Acura RDX
If I remember correctly the oem amp has two/three separate outputs for the door speakers, i.e. the frequencies are crossed over in the amp and then sent to the respective speakers.
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
