LED Fog Lights Installed
Old Oct 11, 2014 | 09:57 PM
Tomtwtwtw's Avatar
So I bought a couple of these -
Lumen® - Acura RDX 2010 Fog Light LED Bulbs
Plasma LED option, white
Ignore all the bug guts on the front...haven't had a chance to give it a good wash yet after my 2200 mile road trip.
Here is the before:
And after:
Side by side - left is LED, right is OEM:
Old Oct 12, 2014 | 12:19 PM
bluecarbonfiber's Avatar
WTF?
so how do you feel about them in comparison? the halogen looks brighter or is it just lens reflection?
Old Oct 13, 2014 | 11:00 AM
Tomtwtwtw's Avatar
That's just reflection, they appear to be very similar in terms of actual light output. I certainly wouldn't recommend buying the 150 lumen bulbs from the link I posted above. Unfortunately I'm not aware of a way to get only fogs on without the headlights so it's hard get a good comparison.
Old Oct 13, 2014 | 11:15 AM
Tomtwtwtw's Avatar
So in doing some research apparently the H11 bulbs are supposed to be like ~1300 lumens, which is 3 times higher than the rating of the LED bulbs I got...I am certainly not seeing that. Do the fogs run at a lower voltage / amperage or something?
Old Oct 13, 2014 | 11:21 AM
Tomtwtwtw's Avatar
More research - although the CarID website says the bulb is 420 lumens, it also notes that plazma LED generates around 150 lumens per watt, and the bulb runs at 11 watts. That would it it closer to 1250 lumens, which is right on par with where the stock halogens run.
So yeah, maybe someone with more knowledge on this subject can chime in and make things clear. lol
Old Oct 13, 2014 | 11:36 AM
RedRyder's Avatar
Be a better driver
Park 15-20 feet from a wall and then take some photos of the output.
Old Oct 13, 2014 | 11:39 AM
WTF?
i did a write up on how to do that you do lose the foglight notification on dash though
no they dont run a low voltage the halogens just look dingy in time
hmm interesting i would think your math is on par for that calculation.. surprised they wouldnt just list them as that lumens though.. most people want 2100lm or above.. i have HID in mine cause i like brighter specially on wet roads at night =)
Old Oct 13, 2014 | 11:40 AM
Tomtwtwtw's Avatar
I'm sure I can do that tonight, but it'll just be for the LED's...don't feel like pulling all those tabs out again just for a light measurement. haha
Old Oct 13, 2014 | 11:43 AM
Tomtwtwtw's Avatar
Right on...if I'm bored on one of these weekends I might get back under there and plug the old bulbs back in for reference then. Maybe on my next oil change.
Old Feb 8, 2015 | 12:52 AM
KenB350z's Avatar
Bright!
Old Mar 18, 2015 | 08:07 PM
Alexass's Avatar
What is the best combination for fogs ? H9 with 65w and shorter lifespan ?
Hid kit h11 for max output ?
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
