HFL and cold weather
Old Feb 15, 2008 | 03:41 PM
aznkingnivek's Avatar
5th Gear
Hi all,
I have a 08 rdx tech. Recently, i have noticed that the HFL isn't working/activated when the car is start in the cold weather (maybe 15 degrees). I can press the talk button, and no beep or anything. However, after like 5mins or more after driving around, the HFL starts working again. I noticed this isn't a problem if it's not that cold outside (35 degrees)
Old Feb 17, 2008 | 03:09 AM
patmryan's Avatar
not to be simplistic, but it sounds like it might be a connection problem with the switch for the phone.. if it is cold enough that the contacts aren't meeting when you press the switch, then you won't get the results... after a while, when the car warms up, the contacts meet and viola... you can make phone calls. I have no idea if this theory is correct, but it seems to make sense
Old Mar 4, 2009 | 05:08 AM
Alex100's Avatar
7th Gear
Same problem
Originally Posted by aznkingnivek
Hi all,
Hi aznkingnivek, did you managed by any chance to resolve the issue w/HFL? Coz I have exactly the same problem on my 08 mdx. From time to time NFL after starting the car do not respond for about 5 min. In addition to that insteed of talk button I'm using back button. Wondering if that's just poor/missed contact or the software?
Old Mar 8, 2009 | 12:09 PM
neo1738's Avatar
2016 MDX Adv/SHAWD
i have same problem 07 rdx, mostly when i press the button the radio turns off, but not beep and it kind of hangs for 5-10 secs, then usually frees up
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
jmaxima03
Sep 27, 2015 10:22 AM
phillyguerrilla
Sep 26, 2015 11:27 AM
