Batt cable corroded, radio wants code ...
Old Sep 6, 2010 | 01:17 PM
zuzzu's Avatar
Unhappy Batt cable corroded, radio wants code ...
My 2007 RDX wouldnt start last night. Popped open the hood and there was MASSIVE blue powder all over the red battery terminal. It was quite loose as well. Cleaned it up a bit w. a toothbrush ... it seems that large chunks of the clamp on the end of the cable are corroded so bad they are missing!
Anyway, it starts again, but the radio wants a code. I am the original owner (in Langley BC, Canada). I cant for the life of me find the card with the code.
Is there any other obvious way to find this code (a sticker on the rdx somewhere?) would giving the VIN to the dealer get the code from them or do they need to pull the radio to get the code from the serial number.
I am also wondering if a corroded batt cable clamp would be covered under warranty or not? This vehicle has about 2 weeks left in its 3 year bumper to bumper warranty coverage.
Thanks ...
Old Sep 6, 2010 | 06:27 PM
XLR8R's Avatar
You definitely need a new battery, once fumes start venting around the positive post seal, it's toast. (Using those red and green felt rings will not help at the rate yours is venting.)
Provided you've been having regular services done, a decent dealer should replace the cable. (ie, someone should have noticed the battery corrosion by now.)
Dealer can retrieve the code as well.
Old Sep 6, 2010 | 08:28 PM
phoward_15's Avatar
My code came with my manual and was placed in the inner pocket of the manual case. It's like a plastic card I think.
Old Sep 6, 2010 | 08:43 PM
MyTL09's Avatar
B A N N E D
Hold down 1 and 6 and the same time and a U and L numbers will pop up write that down and call ur Acura dealer and they will look it up for you
Old Sep 7, 2010 | 07:56 AM
DJ Iceman's Avatar
You can also log into My Acura and look up the radio/nav codes that way.
Old Sep 7, 2010 | 11:21 AM
zuzzu's Avatar
I am logged into My Acura ... where exactly is the code though? I dont see anything obvious ...
Old Sep 7, 2010 | 11:30 PM
DJ Iceman's Avatar
Click on the "Model Information" tab. Over on the right side should be a picture of your car and then a table with your VIN, colors, and radio & nav codes.
4drviper
Apr 23, 2025 07:13 PM
dirleton
Aug 6, 2024 08:19 PM
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
