Autodim Navigation Screen When Headlights are on
Searched, and couldn't find any results, how does the navigation screen turn itself to nightmode when the headlights are on? Checked option in navigation menus and couldn't link anything to this.
This use to be automatic, and it just stays on daytime mode. I always have to push the button to turn it to night or day mode.
This should be a quick answer. Thanks
Not sure of the exact problem, but there are two options.
1) In the Settings, you select the color for night-time and day-time. The night-time colors you select turn on when you turn your headlights on. If they are both set to the day-time colors (beige), then they will not change.
2) The Display button turns the screen on and off and cycles between day/night/off. It's possible you have it on one or the other.
Hope this helps.
Hope this helps.
TecSavi (10-02-2011)
Hope this helps.
Hope this helps.
I knew this was human error, because it was never like that, until i played with the dimmer and forgot. Thanks
Trolling Canuckistan
If you push the nav brightness button on the console and manually switch it between night/day/off the auto dim feature becomes disabled until the car has been shut off and turned on again.
Princelybug thanks for the fix. I was banging my head going through all of the color settings and making sure it was set to auto on switching from day to night. Never would have fixed it without you post.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
