2010 RDX Bluetooth Audio
I have been reading that the 2010 RDX Bluetooth works with Audio streaming but mine will not work. (I have tried using several new and older android phones as well as an iPhone for testing and none of them work.) When bluetooth is connected (I see BT symbol on car screen (non gps). When I hit the "CD/AUX" button it toggles between, USB, AUX, CD, than back to USB.
Any suggestions? Anything I am doing wrong?
Thanks!
Thanks!
I have got an iphone 4 and 5 to work periodically it seems. There have been different threads on this topic, and most say just to hook it up to the USB port to resolve the issue. Sorry, not an answer, but may take away the frustration of it periodically working and having to find the phone all over again.
Thanks!
Thanks!
Also, while I doubt this is a cause, if you bought it pre-owned make sure you unpair any previous BT devices that were linked to the car. You can do it through the BT set up voice commands.
Thanks!
Thanks!
OP - do you have a significant other that also has their phone paired to the RDX? I believe the vehicle will assign priority in the order the phones are paired. For instance, if both my wife and I are in the car and she wants to play some tunes through her phone, I have to turn off the BT of my phone so it disconnects from the car and lets hers play. If that is the case, follow the prompts through the phone set up to delete hers and then re-pair it.
MilanoRedDashR
38
Sep 28, 2019 09:13 AM
nsl752
14
Dec 6, 2016 07:32 AM
navtool.com
Sep 25, 2015 05:15 PM
