[bluetooth] how do I transfer from headset to phone?
I have a TMobile Blackberry, and I was curious if there is a way I can switch from my handset to the HFL while already on a call? The handset automatically goes to BT, but how do I pick up the call from HFL?
-N
-N
Former 07 RDX Tech owner
With my T-Mobile Blackberry Pearl I have to wait for the other party to answer before I can transfer. That may be Pearl specific or it may be Blackberry specific as others report that they can transfer as soon as they hit Send.
Originally Posted by gatorbob
Is there a way to default incoming/outgoing calls to the phone without having to use the "transfer" method?
When you have an incoming call:
1. Hit the HFL button to talk in speaker mode.
2. Answer normally with your phone to use the phone.
3. Answer using headset to use headset.
I hope this helps.
5th Gear
The problem is that when the phone is paired (you can see the "phone" icon on top display) and we make a call from the blackberry or one comes in it does not automatically go through the car's stereo. You have to hit the button and say "transfer" to get it to do so.
Yes, gatorbob, that is the unfortunate way it works at this point for outgoing calls. Even worse with my Blackberry Pearl I have to wait until the other party answers before it lets me transfer - otherwise I get a very polite voice telling me "There is no call in progress".
I've had to train the HFL to learn the names and numbers of my closest friends and coworkers and it is clunkier to use than my Pearl's voice recognition, but at least I don't have to do the transfer very often...
But, on incoming calls they get picked up automatically by the HFL every time for me. Check the HFL settings. I think there were settings for "alert vs. no alert" and "voice alert vs. ringtone". Depending on how they are set it may not be ringing on the HFL and you may have to manually transfer. After I set those up, when my phone rings I get a nice voice telling me "You have an incoming call", I hit the HFL button and I'm talking to the other party - easy as any BT device.
A transfer button would be cool though.
5th Gear
Where the these settings for the HFL found? We have only had the car a week and I'm still trying to figure it all out.
Thanks again.
Thanks, I am used to the system in my BMW that does route incoming/outgoing calls through the car automatically (and downloads the entire phonebook as well).
To setup the HFL, press the HFL button and say "System", then I think one of the options is "Setup" - press the HFL button again before you say "Setup", then it will list other options, including control of notifications.
One of the things I found annoying with the HFL and other voice systems in the car is that it asks you a question, but you have to hit the button again to answer. (By contrast when my Pearl's voice recognition needs more input it asks me and I just answer - like a conversation.) For the first day I was trying to just answer the question and having no luck and getting frustrated.
Originally Posted by sasair
I prefer mine this way. If I have passengers in the car, I want to be able to pick up the phone and use it standalone as a phone for privacy reasons.
It's a shame that there isn't an easy way to either change the default for calls placed by the phone because HFL would be my 99.5% preference - or an easier way to transfer (like a button).
For example, if there is a call being placed by the phone, it would be nice to just hit the HFL button to have it transfer (what else are you going to do with the HFL at that moment - make another outgoing call?). Or, double tap the HFL button means transfer, but single tap means wait for my command (not sure what command that would be, though, other than transfer). This would make it consistent with incoming calls as well - you just hit the HFL button to answer on the HFL if there is a call in progress.
I think the flexibility to answer on handset or by HFL is cool, though I don't have any use for it personally.
I'm not saying there couldn't be some major improvements to the HFL system, but I make do with what it presented to me. I am very used to initiating phone calls from my cell phone and transferring the call to HFL. I am most used to using the phonebook on my cell phone as I used it inside and outside the vehicle. Kind of like navigating the ipod on the ipod. It's the best interface to deal with.
It's certainly better than nothing at all or a third party after market device IMO. Like I'm sure the Motorola Bluetooth kit is pretty good and better integrates with my motorola phone, but I wouldn't want to have it installed in my vehicle....
And it is interesting that the Nav phonebook has an entry for the phone number, but you can't access that through the HFL (like assigning a voice tag to it). It's mostly an empty gesture, or possibly a waste of my time, but I end up entering my friends' phone numbers twice - once in Nav and once in HFL. I guess if I use nav to "Show destination" I then have the option to call them by clicking the button instead of having to use a voice prompt, but it's just silly that they would maintain the two databases separate like that...
(And you may ask why I bother entering my friends' addresses in Nav - precisely to trump all of those "what's the best way to get there from here" conversations one can have as the default chauffeur in a non-grid city. It also gives my OCD tendencies a Zen feeling of completeness when my car knows all of my friends... )
mlody
12-04-2019 02:11 PM
MetalGearTypeS
08-29-2016 08:28 PM
InFaMouSLink
10-30-2015 09:43 AM
SUPRMN84
10-07-2015 09:46 PM
