Water pump recall?
Old Sep 14, 2006 | 01:57 PM
dragontea's Avatar
Water pump recall?
Dealer called to bring in my RDX few days old to make sure the "water pump is torqued to specs"...???
Any other info or calls for anyone?
Old Sep 15, 2006 | 07:59 PM
dragontea's Avatar
seems like there was a factory memo to dealers to check the water pump and make sure it was bolted on and torqued to spec.... just so happens the dealer didn;t get around to checking my rdx before it was delivered to me.... so i had to wait the 45 min for them to check it....
no recall... but a factory precaution memo... someone in Ohio must have fallen asleep on the water pump section...
Old Sep 15, 2006 | 10:57 PM
chyllintsx's Avatar
Missin my TSX =(
lolthanks for lettin us know =)
Old Oct 6, 2006 | 09:52 AM
Ira Hartman's Avatar
9th Gear
Can you possible advise me where this information came from in regards to this factory memo. If i could show it to my service rep.. then maybe he could at least check to see if my water pump is torqued properly. This misalignment could also be causing the idler pulley noise that I have with my RDX..see message thread by Ira Hartman dated Oct. 5th 2006.
your help would be appreciated.
Old Oct 6, 2006 | 02:11 PM
Colin's Avatar
The water pump is outside the path of the timing chain.
Old Oct 6, 2006 | 06:02 PM
9th Gear
Colin could the water pump itself be causing what appears to be pulley noise. i have been using "pulley noise", because to me it is the easiest way for me to explain what I think the noise sounds like.
Old Oct 6, 2006 | 06:07 PM
Colin's Avatar
It's very possible, but remember that this would usually vary with engine RPM and you've stated that your sound does not change when you rev the engine.
Old Oct 8, 2006 | 09:22 PM
rdx4fun's Avatar
Will acura mail us something if are car falls under this water pump recall? Is there a vin range posted somewhere or a way to find out what cars are affected by this.
Jul 16, 2017 07:33 AM
Jboat
Sep 30, 2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
thegipper
Sep 28, 2015 01:01 PM
