My TPMS system shut down today (all sensors report --- pressure), and system malfunction error. As per the photos below.
When I used my scanner to read codes I see 37-01 which means battery low in LR tire. (I could read data stream from all 4 tires however). I'm new to Acura, but surely the entire system doesn't shutdown when a single battery is low? Is this normal behavior?
Yes. When mine went bad, I replaced all, because the others will surely follow. The SH-AWD gets angry, mine even went into limp mode.
