Tire monitor warning
Old 01-15-2009 | 04:57 PM
R*D*X*'s Avatar
I left my RDX outside the garage and when i start my car the next morning my tire monitor preasure warning came up. I live in Chicago and it was -11 deg F. Does anyone encounter this problem?
Old 01-15-2009 | 05:56 PM
johnny99's Avatar
Tire air pressure will drop with the temperature. What was the tire pressure when you got the warning?
Old 01-15-2009 | 09:24 PM
chipmunk's Avatar
This happened to me when I left my car parked at the mountain for the day while I was snowboarding. I got back to the car and the tire pressure monitor came on. I started the car a few times and over the course of several hours but it would not go away. Once I got off the mountain and out of the snow, the warning went away by itself. I think the TPMS comes on at around 26-27 psi.
Old 01-16-2009 | 02:46 AM
cwepruk's Avatar
This happened to me once, but it was seriously cold (-30). I've seen a ton of cold days and neevr had a problem otherwise.
Nothing to do with pressure, it was bascially a system malfunction.
Old 01-16-2009 | 08:52 AM
Scottieb's Avatar
I as well live in the Chicago are. This morning at - 17. and yesrerday as I left the office, I had readings of 26 to 27 on the TPMS, with no warning issues. As i drove on I was soon at 30 to 31 psi. It is the extreme cold and not an issue with your TPMS.
Old 01-16-2009 | 09:41 AM
mwsss's Avatar
Same thing happened to me leaving the office yesterday. Temp was -8 and my warning light was on. After 15 minutes it went off.
Old 01-10-2016 | 11:16 AM
phineasboggs's Avatar
This happens in Florida if the temp goes under 60*
Old 01-10-2016 | 12:36 PM
RDX10's Avatar
Considering this post was from 2009....I don't think those members are here anymore lol
Old 01-10-2016 | 01:25 PM
DRR98's Avatar
TPMS Malfunction lamp on- cause info...
Blast from the past.
The following info is not relative to this^ old post but a good FYI.
We have an '11 and we sometimes get a "tpms system malfunction" warning light. If I pull out our phone chargers the alarm goes away.
Took a long time and many trips to the dealer, who never really did figure this out.
Old 01-10-2016 | 04:20 PM
LOL, I'm still here and there are plenty of 2007s out there <vbg> so it is a topic that some new owners of old RDXs might learn from.
Old 01-11-2016 | 12:37 PM
Jdrum1's Avatar
Looks like some of us forgot 8th grade science!
A little lesson on air temp vs. air pressure:
Tire Tech Information - Air Pressure, Temperature Fluctuations
Old 01-12-2016 | 11:44 AM
rsxdude's Avatar
I had a similar issue but my friend has a tpms scanner and one of my tpms sensor battery was low. Maybe have your dealer check the battery level of each sensor? One sensor not reading correctly will cause the tpms malfunction lamp to kick off. I just replaced all four of them since its a 2008. No issues since.
rockyboy
08-04-2024 10:35 AM
Rob144
09-21-2015 08:18 AM
robm
09-18-2015 07:53 AM
PortlandRL
09-14-2015 12:01 PM
Quick Reply: Tire monitor warning
