Rubber Window Trim Replacement?
My 2011 RDX has worn rubber window trims (outside bottom window). Worn as in the rubber at the ends are basically detached and just sticking up on the window. The rubber is relatively brittle as well, and does not wipe any dew off in the morning when the window is opened and closed. I have checked pricing to replace all four, and it would be approx. $80 apiece, or $320 in total. Does not seem to be any aftermarket cheap clones either. So other than the windows will not clear if dew is on them, how important is it to have these window trim pieces properly sealed or touching the window? Anyone replace these with cheaper parts from somewhere? Thanks.
