Roof Rack
Old Nov 10, 2007 | 12:46 AM
preacher's Avatar
Turbo Junkie
Roof Rack
First of all, the dealer tried to tell me it would cost $1000 installed...uhh no thanks. :thief:
My question is, has any one installed just the roof rails, and attached an aftermarket roof rack system (Yakima,Thule).
Second question, how hard is the install? From the notes, it seems that drilling is involved, and wondering if it was difficult, or should I buy the rails/rack and have the dealership install?
Old Nov 10, 2007 | 01:05 AM
benlee78's Avatar
07 MDX Base
I found a couple of places on the web site that discussed this:
https://hondacuraworld.hostasaurus.c...dxroofrack.pdf
https://acurazine.com/forums/showthread.php?t=1481
Old Nov 10, 2007 | 07:26 AM
voigt's Avatar
My sister brought her roof rack from the dealer online and saved a ton of money then we installed in on her 2007 CRV in no time. I am not sure about the RDX but I don't think it would be to hard. You can get after market Yakima or Tule (sp?) Which don't require being drilled, they clamp on.
Old Nov 10, 2007 | 01:25 PM
preacher's Avatar
Turbo Junkie
Thanks for the link..and the pdf install notes.
I see nothing about drilling, so that solidifies the idea that salesmen really dont know much about aftermarket stuff. duh..
I will be taking this on as my first bolt on "mod". I think I will get the crossbars too, for an extra $100.
Old Nov 10, 2007 | 03:52 PM
holders's Avatar
if you're interested, i bought an rdx with roof rack... but i'm going to remove it. if you're close to toronto, maybe we can work something out
Old Nov 10, 2007 | 04:50 PM
BleuM&M's Avatar
User-approved
You have to cut sections from the roof molding to install the rail brackets. Here's the link to the installation instructions: http://www.handa-accessories.com/rdx/rack.pdf You can also check the site this came from for the pricing - I use them a lot for my accessories.
Old Nov 11, 2007 | 02:57 AM
preacher's Avatar
Turbo Junkie
^^Your link is for the install..
Holders pm sent..
Old Nov 14, 2007 | 01:03 AM
preacher's Avatar
Turbo Junkie
I will be going thru the vendors for the rack system, and posting my own install notes, once I do so.. eff the markup stealerships....newbs!!
Old Nov 14, 2007 | 11:55 AM
mav238's Avatar
Curious...
How many people who installed roof racks actually use it regularly... ?
I have never thought of putting stuff on the roof of my RDX, and thus never thought of installing one.
It may make my RDX look more "SUV"-like... but I think for my personal needs, it is just extra weight and negative impact on aerodynamics, the RDX can do without.
Old Nov 14, 2007 | 12:38 PM
johnny99's Avatar
The roof rack should be sturdy enough to carry skis or bicycles. If you don't use either of those, or you carry them inside the car or on a hitch rack, then I agree that the roof rack is not worthwhile.
Old Nov 16, 2007 | 11:03 AM
waterlou's Avatar
Anyone know what the weight limit on the rack is?
Old Nov 16, 2007 | 02:19 PM
sasair's Avatar
I believe it is 80lbs
Edit: correction, it is 110lbs
Old Nov 16, 2007 | 05:46 PM
BleuM&M's Avatar
User-approved
My rack was already installed when I bought the RDX. First thing I did was remove the crossbars to reduce drag and whistle. I'm sure I'll have use for them at some point...
Old Nov 21, 2007 | 10:55 PM
XDRARUCA's Avatar
I bought the factory racks from Ebay for about $300 and installed them myself according to the instructions and tips found on this site. The first molding is a little difficult to remove, but once you get familiar with it, it's easy. Cutting the moldings is simple, and you do not have to be exact as the mounts cover the cuts. I did not install the crossbars as I have the Yakima lowriders and crossbars. I carry 2 mountain bikes on Yakima racks or 2 15ft Ocean kayaks at a time.
If you're not handy or comfortable doing modifications, take it to a dealer. If you've done mods or customizations, or have experience doing handywork, it should be easy.
Old Nov 22, 2007 | 02:27 AM
preacher's Avatar
Turbo Junkie
Thanks for the update..
I have my eye on the $300 e-bay ones as well, as it seems most dealers offer it at that price.
As far as install, the directions are straight forward, and seem easy to do.
The dealerships think is a "BIG' deal for install b/c you do have to drill on the MDX.
Not the case w/ the RDX... cut~N~tuck.
Old Nov 22, 2007 | 02:00 PM
XDRARUCA's Avatar
When you do it, be sure to be careful taking off the trim and not to tear the rubber molding around the windshield. Also take note of the Left and Right pieces. Or you'll have to re-mount everything the correct way.
dirleton
20
Oct 16, 2015 01:48 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Froid
Sep 27, 2015 06:16 PM
jmaxima03
Sep 27, 2015 10:22 AM
spoiler900
Sep 23, 2015 04:41 PM
