Reverse Tilt Passenger Mirror
'07 Moroccan Red Pearl
Hi all,
This morning when I put the RDX in reverse the passenger mirror tilted down as usual but never went back to its normal position. I had to adjust it manually. Has this happened to anone else?
ummm.... okay, I must be really silly or just so numb to the functions of my RDX, ...
Does the rear view side mirror on the passenger side actually tilt down on reverse???
I've heard the RDX only has the right side that does this, unlike the TL.
Aint Doing Sh*t
Originally Posted by Tripp11
My TL has the option of choosing which mirror you want to tilt down when in reverse. You toggle the mirror selector switch to L or R (not the center position) and when you put the car in reverse, the appropriate side mirror tilts down to give you a better viewing angle of the curb.
07 RDX w/Tech
It certainly does - but only when you have the switch to adjust the mirrors is on the passenger side mirror. I like it, but I've never had an issue with it returning to its normal position once the vehicle is back in drive.
Originally Posted by Claire
Hi all,
cool... hmmm... the sales pserson didn't explain that to me...
Anyway, now I know that, I'll be using that more often now...
Thanks guys...
Originally Posted by catnippants
Does the mirror still function properly otherwise? There are some notes in the service bulletins regarding failing mirrors....
Mike
Mike
I'll check out the bulletin, thanks
The August, 2006 Acura service bulletin discusses problems and fixes for the right side mirror tilt-down feature. Look in the "problems & fixes" sub-forum for copies of the service bulletins.
Hi all,
Originally Posted by turboted
ummmm...yes! Flick the side mirror switch to the R, right position, the mirror will flip down when you reverse.
I just didn't know the RDX came with that feature...
ITSJESTER
17
12-06-2018 02:29 AM
navtool.com
31
11-16-2015 08:30 PM
