RDX TPMS question
Old Dec 22, 2014 | 07:52 AM
high-octane's Avatar
4th Gear
Question RDX TPMS question
I am a total newbie when it comes to TPMS and need some information on it. I am so glad I found this site.
Just bought a 2011 RDX and am going to install a new set of winter tires (separate rims, new tires, new oem tpms sensors).
From what I have read, the rdx should relearn it automatically after driving for a bit however I am not sure if relearning is the same as reprograming?
Questions:
1. Is relearning the same as reprograming?
2. Do I need to activate the sensors?
3. If yes, does this require a special tool?
4. How do I reprogram the sensors?
Any information on this will be much appreciated.
Old Dec 23, 2014 | 09:59 AM
Tomtwtwtw's Avatar
Questions:
1. Is relearning the same as reprograming? - essentially, yes
2. Do I need to activate the sensors? - not sure, may want to check with dealer. But in general you do not have to activate
3. If yes, does this require a special tool? - n/a
4. How do I reprogram the sensors? - On the RDX, I believe each sensor has a dedicated receiver in / near the wheel well. This means your car always knows which sensor is at which corner so no reprogramming needed after rotations either.
TL;DR - 4 new tires with 4 new OEM sensors should work perfectly once installed and mounted with no other action needed on your end.
Old Dec 23, 2014 | 10:18 AM
4th Gear
Thank you for the information Tomtwtwtw!
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
bailey24
Nov 21, 2015 08:43 PM
lland
Oct 4, 2015 04:47 PM
d.lim
Sep 15, 2015 08:54 PM
datadr
Sep 12, 2015 09:12 PM
