RDX leaking coolant
RDX leaking coolant
Happy Thanksgiving to all.
I recently discovered some wet spots on my driveway, and I look under my car and I can see the blue coolant, dripping from the bumper. I take the bumper off and see the leak is coming from the radiator. Anyone know if this is going to be a big repair, or some leak proof product from Walmart would solve the problem?
A little info of my car, I have a 09 RDX w/ about 45k miles. I'm the original owner, and the reason for the low miles is the 1st two years, the vehicle was only used in snowy condition. Never any front end damage.
But in this application, I doubt you would want to use this type of product even if it did exist for the radiator. Did you check and see where the leak is exactly coming from? Is it a loose/cracked pipe or it could even be a crack in the radiator. Depending on where the leak is coming from, that would define cost and ease of repair.
If you plan on keeping the RDX for a while I wouldn't use any of the coolant system sealers. They do work great but they can plug up your heater core and you'll get little to no heat over time. If your keeping the car fix it properly replace the broken part.
Thx for the replies. I do plan on keeping the RDX for a few more years. I just discovered this leak from removing my headlights to get some work done to it.
I've been doing some searching, and reading other post of ppl having trouble with leaking coolant. I'm sure there's no crack on the radiator, since anything inside is under pressure, and the leak is a very slow drip. I'm hoping it's some bad clamp or hose with an ez fix.
I went back and tried to look again, and I found the leak is corroding this piece, so I better get it fixed before more problems down the road.
Every Honda product I've ever owned eventually developed a leak where the aluminum and plastic are crimped together.
I always replace will all aluminum aftermarket models (with 100% success so far).
My RDX is on it's original, but I'm sure to keep a close eye on it!
So I ended up getting a new radiator. The Acura sites wanted $311, so I ended up getting the Denso one from partsgeek.
I think it cracked cause I wasn't driving my RDX hard enough. I will from now on drive with a lead foot.
^DENSO is the OEM Radiator. So you did VERY good!!!
and no, thats not the cause of it.
the posters above you mentioned the cause....the seam where the aluminum and plastic are crimped together gave way.
Can you guess why two different materials will give way?
temperature and maybe a corrosive agent like salt.
Originally Posted by skyknight88
I'm sure there's no crack on the radiator, since anything inside is under pressure, and the leak is a very slow drip..
![Spit](https://acurazine.com/forums/images/smilies/spit.gif)
I'm glad you saw the light and didn't leave any stone unturned.. Sometimes the "there's no way that could have happened" is the one thing that happened.
Funny aside, we once owned a murano and I was scared shitless to take that POS far away from home because it had a damn cvt.
I would also check your ATF and get it replaced asap. The place where that leak occurred is actually an ATF part of the main radiator and both coolant and atf could have mixed.
Update on my situation.......got new radiator and had the old one removed. The pix will tell you the whole story.
![](https://cimg1.ibsrv.net/gimg/acurazine.com-vbulletin/2000x1124/20151218_070337_9a520a34f6cce9435c7643c1855ceb6b21c69ec1.jpg)
![](https://cimg0.ibsrv.net/gimg/acurazine.com-vbulletin/2000x1124/20151218_070341_6c397ea454cb2d63b9dd29b9deb175ef8f1237a2.jpg)
I'm in Massachusetts, and last winter we had a very tough winter with a lot of snow. Some of you lucky ppl living in areas with little to no snow may not experience this. Hopefully the new radiator will hold on longer.
Acura604
2G RDX DIY & FAQ
17
10-16-2022 11:06 PM
jeremy cudal
11-25-2015 08:04 PM
bg2128506
11-25-2015 03:03 PM
