rdx 2010 - front bumper removal process
any idea how the "hooks and side spacers" work on 2010 front bumpers? am helpng work partner change his fogs this wkend. does one just pull out the bumper on front wheel arch areas similar to this link i found for a civic (see step 3- which talks abuot hooks and side spacers - same principle in rdx?)?
http://www.greenhybrid.com/discuss/f...dlights-17176/
sorry for the multiple posts-cant seem to edit (guess i hvnt reached the requrd posts to edit).
as addendum quest: so we tried to "pry out" the 2010 rdx bumpers at the wheel area areas to release it from hooks on the side spacers this early morng. we stopped and the car's now just in the garage of my center city (philly) friend LOL. how much force should we exert to pull this out anyway? (note all screws are out) yet there seems to be hooks on the headlight and side spacers near the front fenders... any insights? thansk
I was able to remove the bumper easily. Remove the plastic fasteners on the top (around the grill area between the headlights) and botton (connecting to the splash guard). Remove the screws on the wheel wells (there's a screw on the bottom).
Now that the fasteners are removed, the bumper is now held in place by snap-in-like areas around the headlights. Just gently pull on it (starting from the corners of the headlights) and it will pop out.
thanks again.
What wspy said
It has "tongue and groove" attachments.
I was able to take it off by myself (using my knee to keep it leveled as I removed both sides and the fog light connections) when I installed my 3000k HID fogs kit (only $38 off ebay!). I got help to put it back on tho.
is there any way to correct this issue? or shld it be expected then given that we already removed and reattached and therefore shldnt expect as tight a fit vs. factory. (eg. its plastic so if you pulled it out (even gently), dont expect the exact same fit when reattached)
FWIW, it's not very noticeable unless you really go close - prolly the gap is the size of 1/16th to 1/8th of an inch maximum (hence why i didnt bother posting pic). we just noticed it comparing my 09 to his 10 RDX
(but he's got nicer fogs now LOL)care to share your experiences?
correction, my factory installed is even less than 1/16th of an inch gap b/w headlights and bumper. cant edit my posts still so apologies
Yeah it should pop back in place. Perhaps a tongue was not in its groove? It should pop right back in as it was before you removed it. I almost made the mistake of reassembling the bottom splash guard wrong (on the wrong side of the fastener).
however i stand corrected, what i can see now are the "holes" in the bumper and the side spacer "locks/hooks" (just as the bumper meets the front fender, headlights vs bumper have no gap). it's aligned for sure, just that there's a very very small gap no (need to use flashlight to see the gaps, lock/hooks). i guess the bumpers a bit too flexible (both good and bad
that when i pried it out i had to re"fold" it (to turn it back to orginal state - which i didnt). no biggie though i think part and parcel of pulling out and putting back bumpers in. just wont be the same as factory "tight".thanks fr the help
I ordered replacement plastic clips before removing my 08 RDX front bumper to replace my HID bulbs. Half the clips were either missing or broke during removal because of age. I got an assortment pack because some of the holes on the under side wore larger than the standard clip size. The extra clips came in handy for my 06 TSX, 11 MDX, and my daughter's Mazda 3.
Amazon, $14 for 240 clips:
Fatfooted
1G RDX (2007-2012)
Nov 6, 2014 02:50 PM
amfsumo
1G RDX (2007-2012)
Dec 17, 2010 09:43 AM
. The bumper is quite flexible and will not deform
