Question Regarding the Brakes in 07 RDX
So this is my first post here I am new. I bought my RDX used in October last year with 108k on it. I have noticed that the brake pedal was getting further and further to the floor and there was lots of grinding when coming to a complete stop.
Yesterday I did a full brake replacement with four rotors and four ceramic pads. The pedal is much better now but still seems quite far down. I used a power pump bleeder on all four calipers and bled them in the order somone mentioned on the forum. The front calipers bled very nice and I was able to get the fluid to change to a clear new fluid with about two fluid exchanges via the small container. The passenger rear caliper would not bleed much fluid at all in fact it was mostly air bubbles coming out of the line. Could there be an issue with this caliper and would it cause my pedal to be lower to the floor? I was able to get the piston to move after compressing it via caliber compressor. I also tried to bleed that caliper the old fashioned way and still didn't get much fluid out.
The old rotors were quite bad so I am guessing they were original?
This is the bleeder.
Well I spent probably close to half an hour on that right rear passenger caliper. I even tried the old fashion way. Could that caliper be bad? I can take the tire off and try to re-bleed again. All of them except this one bled well. Yes, I also made sure to keep topping off the brake fluid in the reservoir. I did notice that the bleeder valve is really high off from the caliper almost like its not the correct valve. All of the other calipers have valves that are flush on the caliper.
rockyboy
Aug 4, 2024 10:35 AM
