Put new brake pads on, amazing difference, highly recommend!
In some other threads people have been talking about the brakes on the RDX. Especially that they were less-than-confidence-inspiring. I also felt that they seems a little slow to respond, and found myself being extra careful to leave more space than usual between myself and other cars because of that loss of confidence in the responsiveness. Well, I didn't want to buy a whole braking system, and I have had great experience with just changing the pads on vehicles before, so I bought a set of EBC YellowStuff 4000 SUV pads for the fronts on the RDX.
First, in case anyone wants to know, the front pads are a breeze to install on the car. Lift the vehicle, take off the wheel, and there are only two bolts that you have to remove to switch the pads: one is the upper caliper bolt, this lets you rotate the caliper out of the way, and the second is a little bolt holding the brake hose in place, this gives you enough room to finish lowering the caliper all the way and completely out of the way. The old pads pull out, the new ones snap in, and voila', just swing the caliper back up, and bolt the two bolts back on. Put back your wheel, you are done with the installation.
I picked the Yelllowstuff 4000 SUV because it is the most agressive without being a true racepad that requires heating up. This is a street vehicle after all. However, EBC brake pads do require a 'break-in' period before they bed completely. It's pretty easy. basically it involves taking the car out for a drive, and repeatedly stopping from about 40 miles an hour, more and more quickly. It also requires about 100 miles of driving. Now, that doesn't mean the brakes don't work during that time, it just means that they are settling in. As you drive the car, you will notice that your braking is getting quicker and quicker. When you first start off, it already feels a little more responsive that the original pads, but after the 100 mile mark, it's amazing. It now feels to me like a BMW brake in terms of responsiveness, intial bite, and much quicker stopping.
While the break-in is occuring, you will also hear squealing while it settles down. It took me about 140 miles to get it to completely get quiet, but I've driven it all weekend about 200 miles, and it's fantastic.
I had high hopes and it exceeded my expectations. I would recommend these pads to any of you who want to feel that type pf confidence again in your vehicle.
The pads were about $100, but well worth it in my opinion. Installation of the pads took me about 15 minutes for each side.
If anyone is in my area of the world [San Antonio], I can help you install them in my garage if you have never changed brake pads before. Or if you want to see the difference, bring over your RDX, we can drive them back to back so you can feel the responsiveness vs your stock pads.
Anyway, I thought I would put forth my positive experience.
is ebc yellow a semi racing pad?? I am looking to get ebc green. I think green will be better for canada winter.
can you post your ebc yellow part number please.
I also have just install a set of EBC brakes over the weekend... I purchase the Greenstuff 7000 SUV Pads...
As posted above... Installations was simple.... took me 30min for both side....
After the install... took it for a spin.... and GOD what i difference..... i no longer need to step on the brakes hard to stop the car.......
But i do notice there is a bit a squealing.... Hope this will go away later on.......
Higher recommended to anyone......It cost me $120 (CDN....Freaking Tax!!!).....
Good review and great purchase made!
I have considered many times for EBC pads, but sort of stayed away, due to the harder material used in these brakepads. Hence the tougher grip, it can be a llittle harsh on the rotors, so I stayed with oem pads for the civic. Noticed I said civic.
I am sure that you purchased awesome pads that performs, but I will have to pass on the RDX; although, I will buy a set for the civic. I almost had an encounter (civic) over the weekend with the stock pads and "brembo blank" combination. HAWK pads are also a good brand to buy.
Cool! I've been looking for something to improve the RDX's stopping power. Has anyone tried switching the rotors for the RDX as well? http://www.innerauto.com/store/produ...=brake_pad_set
The above link recommends the EBC sports rotor with the application of their EBC brake pads.
Questions and part #
First, here is the part number I ordered:
DP41743R
As someone else posted, you could go with the GreenStuff, it's still going to be better than stock [at least it sounds like it].
I talked with EBC about the pads being more agressive. According to them, it will reduce the life of the rotor by about 10%. Since rotors last a long time, if I can get 30,000 miles out of them, it was well worth it. I don't see why I can't get at least that amount. My previous cars all went closer to 60,000 before needing a rotor change, so I think I am being pretty conservative.
As for the squeal that someone else noted, as I said, and it says on the box, give it about 100 miles to set and the squeal goes away. On my box, it actually says that if you go 200 miles or so, and it hasn't gone away, they'll give you your money back.
For the person in Canada, there was a question about using it in the winter. These are street pads, the don't appear to have any temp limitations. Now, the RedStuff version full racing pad IS something I would not use, since it does have temp restrictions on it. But the YellowStuff for our vehicles is a street pad for heavy vehicles. There is also not supposed to be very much dust with the YellowStuff.
If anyone has more technical questions about things like that, you can also email the technical support at EBC Brakes, they are in the UK, so there might be a delay depending on the time you send the email, but they will respond. They seem like good blokes to me
technical@ebcbrakesuk.com
cartechnical@ebcbrakesuk.com
Thanks for the feedback, I just know that this was an area that people have had some regrets with, and I think this addresses it pretty well and doesn't take very much time.
Thank you, EBC for a well needed product.
DP41743R
Would you consider getting different rotors? or stick w/ stock.
I figure, if your going into the brakes, why not do the whole thing?
including changing the 07 suspension..hehe
Diggin' the RDX!
Good info to have, thanks for posting it. I have found my RDX brakes to feel quite responsive for an SUV; maybe that's because I am used to driving my gf's XL-7 which is a monster to stop! Ha.
No need for rotors
Nyjumpman,
I don't think I would change the rotors, I think the vehicle has everything it needs. It's just right, I don't want it to be toooo sensitive and I think a better rotor would be more than I want for my RDX.
Originally Posted by happywithmyrdx
Nyjumpman,
Wow, great info! Stock RDX pads due tend to fade some. Three questions...
1. $100...does this replace pads on all four wheels?
2. Web site where I can purchase these pads?
3. Replacement sounds simple, but anyplace on the web with step-by-step pics of process?
Not that it makes a difference for this thread, but I just picked up a set of EBC greenstuff for the civic at buybrakes.com - their coupon for $10 off (expires august 31) still works!
I drove the RDX earlier tonight and played with the brakes. I honestly do not have any complaints, although, it may seem a bit unresponsive at times, but it's managible. Unlike the civic, I do not drive as spirited in the RDX
haole kama'a-ina
Originally Posted by Boon
Are there any brake pads out there that won't wear down the rotors? Or will this be typical with any sort of upgrade that we do?
The EBC pads were effective, quiet and low dust. After 35000 miles I had about .015mm rotor wear. Couldn't have measured it without my digital electronic caliper.
Originally Posted by 737 Jock
When I had a Touareg (5300 lb SUV) I installed EBC GreenStuff pads on new OEM rotors. (The OEM pads had worn 4 mm into the rotors.)
haole kama'a-ina
Thanks man. Just out of curiousity...how much wear can the rotors take before they need replacing?
From the RDX Service Manual:
Front disc measures 28 mm new and refinishing limit is 26 mm (page 19-15).
Rear disc measures 9 mm new and refinishing limit is 7.5 mm (page 19-27).
Some may interpret that to mean the disc may be refinished once if it's at the limit.
My take is 26 mm and 7.5 mm are hard limits; replace.
Min thickness is stamped on the rotor. Some companies publish min service thickness, but Acura publishes a refinishing limit.
Updates and answers to other questions here....
Someone asked if I did all four pads:
I only did the front pads, it stopped so well I didn't change the rears. It was a gigantic difference.
Someone asked about rear fade:
I've put on about 400 miles with the new pads. I don't experience any fade whatsoever with repeated braking from 70 mph. This is why I chose the yellowstuff over the Greenstuff version, to also remove fade from repeated stops.
Someone asked about pics:
I really should have, but I didn't take pics of the brake pad change, if someone wanted to do it, I could walk them over the phone while they were doing it, it's that easy. Then maybe they could take the pics and post them for all of us Seriously, if someone was interested in doing the change, I would give out a phone number and we could schedule a call, I'd love to help out another member that might be nervous about it.
No dusting whatsoever occurring with these pads either, much cleaner wheels than the OEM.
Oh and...
Someone asked about year:
it's an 07
Someone asked about a web site:
Yellow and green stuff:
http://www.autopartswarehouse.com/pr...model_text=rdx
or
http://www2.partstrain.com/partlisti...+Brake+Pad+Set
it's an 07
or
El Chulo...
colored stuff...
Happy, did you install the regular yellow pads or the SUV yellows. I ask because im seeing that the Regular Yellow brake pads are "FRONT YELLOW STUFF BRAKE PAD SET -- Yellow Stuff, The Ultimate Race Brake Pad For Highly Tuned Cars On Both Street And Track". They seem like overkill for the RDX, So Ive also seen the SUV version of the yellows and was interested if those were the ones you actually have. Any feedback would help. I want better stopping power ASAP!!!
Yellow Stuff responses
I used the Yellow stuff because it was the best braking pad without going to a race pad [Red Stuff]. I figured since it is a heavy vehicle that the Yellow would be a better choice, since I would rather have a car stop even faster than I hoped for rather than be underwhelmed by the lower rated pad. However, I am hearing from people now that the Green Stuff Pad is also a really good pad and that people felt a tremendous improvement with it also. I'm sure part of this is personal preference. If you feel that the brakes are pretty good already then a Green Stuff pad might be just fine. I wanted to see what was the absolute best I could do with just a pad change, because if that didn't satisfy me, then I was going to put on better rotors, and if I thought I was close enough, I would add the EBC pads to the back brakes also. This way there was no second guessing. I suppose if the brakes just locked up so hard with the yellow stuff that I was unhappy, I know then I could just step back to the Green Stuff and be done with it. It's like a good intermediate step for me. The only real tradeoff was that it did take closer to 200 miles to break the squealling noise, then they went nice and quiet again.
NYJumpman 23 asked about 08, I check with EBC and they said it was the same pad as the 07's.
They would only kill the warranty, if the pads were to be a direct cause of failure for whatever part that might be covered under warranty. Like if you're under 12K miles and 12MO, and the rotors were warped, they would not be covered under warranty.
Is everyone who thinks the brakes are soft driving an 07? I test drove the 07, and agree that the brakes were terrible. I bought the 08, and the brakes seem rather good. Any chance this is another minor improvement made to the 08?
Warped rotors...
Brake pads themselves are not covered under warranty, but I suppose a rotor might be, even though it is a consumable. If the rotor warps, it's probably because it was prone to warping more than the pad. I did have a Honda that warped rotors, but it did that with stock pads.
Originally Posted by porsherules911
What is everyone's take on this? I just turned 15k miles on stock rotor and brake pads and I can feel that the rotor is starting to warp just like it did on my Honda Pilot. Do you think Acura would cover the warped rotors?
Subscribing to this thread. Who ever decides to change their pads next, please...please post pics. Tks.
HappywithmyRDX: You don't need a c-clamp to compress the brake piston? Just simply snap the pads into place and bolt the caliper back on?
