Panorama On/Off? 08 Tech RDX
Ok, I'm not sure if this has been post before. Today I had something right in front of the shift knob and when I shift to "Park" the package accidently push and hold the Power/Vol knob. Then I heard a beep and I noticed the upper display showed "Panorama Off". Then I tried again and it went to "Panorama On". I was wondering what is "Panorama On and Off"? I tried searching on the Owner's Manual but nada!
Appears to be a function of the Panasonic audio system and Dolby Pro Logic. Panasonic home theatre systems have Panorama function. In the RDX, I could not duplicate the "panorama off" message unless Dolby Pro Logic was set to "on"
I dun have an answer but this is what I think of it.
I think it has to do something with the audio more than anything else since it's the power button for the audio system. It's confusing that the system uses the word "panorama" though since it implies something visual rather than audio.
Does the sound change at all? like more surround sound when it's on rather than off?
I did notice a bit of difference on the audio when I had panorama on and off. I never used panasonic home theater before. Good to know, cuz at first I thought it "panorama" meant something about panoramic roof or a panoramic view on the navi.
catnippants, try to push and hold the power button. Then turn the button while been pushed. You should be able to change it from off to on or visa versa.
Other thing I found that you can change when in this mode
Yes, Prologic needs to be on. Then hit and hold the power knob. In the upper display the Panaroma comes up and you can turn it off and on. I also found that when you are in this 'mode" and then hit the preset 3 it changes to "center width" and you can change the value. Then if you hit the number 2 preset you get "dimension" which again you change. You will definitely hear a difference then you change these. They seem to have some thing to do with the sound channel settings.
So I did a little searching for definitions/explanations on the web. If the parameters are the same as with Panasonic's home theater systems (as mentioned by a previous poster), then here are some explanations - found in two different places. They definitely appear to be related to ProLogic II. Frankly, I'm surprised that they aren't documented in our manual....although I really don't see them as being very useful.
Source 1 - Panasonic Home Theater System manual
PANORAMA
Sound is spread more so you feel like you are surrounded by
music.
Center Width Control – C-WDTH
You can choose a level between 0 and 7 – the higher the level,
the more the sound from the center channel is spread into the
front speakers.
The default is level 0.
Dimension Control – DIMEN
You can choose a level between 0 and 6 – the higher the level,
the more the sound moves to the front.
The default is level 3.
Source 2 - Crutchfield
DPL II Effects: When in Dolby Pro Logic II's Music or Panorama modes, you can adjust the center width and the dimension control. The center width helps you realize a more natural sound image when listening to music by moving the sound out into the front speakers, or add sound to the center speaker to fix the center image. The dimension control can make up the differences in the output level of the front and surround speakers.
Mike
PANORAMA
music.
front speakers.
Mike
PANORAMA
music.
front speakers.
Mike
PANORAMA
music.
front speakers.
Mike
You're welcome - but I guess I'm rather disappointed. I was hoping for something more dramatic. Seems rather pointless to me since we already have a separate center channel volume adjustment and a fader. That may be why they didn't bother documenting the parameters...
Mike
Mike
visiter555
04-09-2016 12:56 PM
Barb Jackson
09-15-2015 02:27 PM
