P0303; chugging
Old Apr 5, 2024 | 09:04 AM
FlopMeister's Avatar
P0303; chugging
Started car this morning, and it was chugging, running rough. Then the dash lit up. CEL is flashing/pulsing. Plugged in my flash pro & it said P0303.
just changed plugs (second time over life of vehicle. Been about 60k miles I think). I also swapped the coil packs between cylinder 2 & 3. Now the code is P0302 with same symptoms. Plugs looked dry. Coil packs are original.
but dam! $124 for one ngk pack? Can’t I just use the duralast for 237 for 4?
155k miles. Any thoughts folks?
what is the cylinder sequence from left to right? I switched the second from the left pack/cylinder with the one to the right of it.
Old Apr 6, 2024 | 11:23 AM
Fixed….i hope
changed all 4 plugs & 4 coil packs. Sorry guys, I went with the duralast coil packs.
Old Apr 12, 2024 | 01:09 PM
yanga001's Avatar
Coil packs are one of those things i usually grab used at the yards as they are an all or nothing failure. Do this for my volvo and my partners acura.
Old Apr 20, 2024 | 12:49 PM
DaIll1's Avatar
I'd use used ones if you didn't have to disassemble the top of the engine to replace one. I bought my RDX with 160k miles. I replaced all 4 plugs and coils while I was upgrading parts.
Old Jul 10, 2024 | 09:57 AM
rb92103's Avatar
8th Gear
Had this issue and it was the coil.
How does the Duralast works for you?
guitarplayer16
Nov 13, 2020 07:25 PM
AMart83
Oct 7, 2014 11:40 AM
raleightk
Feb 23, 2011 11:18 AM
rxphiler
Aug 25, 2009 10:54 AM
SupaRookie
Apr 26, 2008 07:51 PM
