P0303; chugging
P0303; chugging
Started car this morning, and it was chugging, running rough. Then the dash lit up. CEL is flashing/pulsing. Plugged in my flash pro & it said P0303.
just changed plugs (second time over life of vehicle. Been about 60k miles I think). I also swapped the coil packs between cylinder 2 & 3. Now the code is P0302 with same symptoms. Plugs looked dry. Coil packs are original.
but dam! $124 for one ngk pack? Can’t I just use the duralast for 237 for 4?
155k miles. Any thoughts folks?
what is the cylinder sequence from left to right? I switched the second from the left pack/cylinder with the one to the right of it.
Chopperpilot (04-07-2024)
I'd use used ones if you didn't have to disassemble the top of the engine to replace one. I bought my RDX with 160k miles. I replaced all 4 plugs and coils while I was upgrading parts.
Chopperpilot (04-20-2024)
