New RDX Review
You'll Never Walk Alone
Just checked Motortrend, the RDX's engine spins at 2050rpm at 60mph in 5th gear. I guess that's part of the reason for the hwy fuel economy being not as high as expected. For reference, 1850rpm for CX7, 1700rpm for Rav 4.
As I was looking up for the above information, I came across this review of the RDX (it's old, dated back in September). But I thought I would like to share it with some of you. It's quite interesting that they compared the acceleration, slalom speeds, and braking with the BMW 3.0i (not the newest one) and CX7. It says that the RDX can do 0-60 in 6.8s, beating both the BMW and Mazda (they both need more than 8 seconds). Also the slalom speed is 2mph higher than cx7. But the braking distance is 127ft, which is 4 ft more than the mazda, and 9 more than the BMW (with sport package).
http://www.edmunds.com/apps/vdpconta...3/pageNumber=1
As someone already posted, it's close to 2000 rpm at 60mph. I think it's still under 3000 at 75.
There is rarely much boost at fairly constant highway speeds. The only time I've seen max boost in top gear is when I've slowed down from a fairly high cruise control setting, and then let the car get back up to speed. It does not downshift but does max out the boost.
Acuras since 1988
Goes to show that its hard to write a bad review of this car especially if you get to drive one for a few days on some windy roads, thats where its so much fun to drive. I mean sure there are some minor things that could be tweaked, but whats really not to like! ( so far, fingers crossed)
Originally Posted by Animagix
i think something like 2000rpm's. I'm concerned about where max boost kicks in. because cruising at 80-85mph with max boost isn't good with the gas.
Got Boost?Rdx/Base/CGP
Well me..I NEVER liked the CX-7. 1st it looks ugly..but i know that the rdx is WAYY BETTER than the CX-7..me when i only accelerate a lil bit the boost meter go up way fast! im proud to have the Rdx!well first i had an eye on The New ML-500 from M-B..bcuz i havethe M-b ml500!..i have a question..do they sell body kits for the Rdx in montreal?
thx
sincerly Rdxowner
thx
sincerly Rdxowner
Originally Posted by sasair
Isn't the CX-7 mileage rated the same as the RDX?
Ok, RDX has a 99mm stroke, CX7 has a 94mm stroke...so I guess the pistons inside the RDX is travelling more distance than the CX7's. Also the CX7 has a CR of 9.5:1 and RDX has a CR of 8.8:1. So theoretically, the CX7 should be more efficient. But I think the variable flow turbo in the RDX is very effective, so in the end the RDX gets a little bit better mileage than the CX7.
Please correct me if what I said was wrong, thanks.
joflewbyu2
08-18-2019 10:38 PM
ITSJESTER
17
12-06-2018 02:29 AM
