Need some input
Old Mar 22, 2021 | 07:43 PM
NaturalFlavored's Avatar
Need some input
Ok its a little hard to get a video/sound of this but is there anything out of the ordinary that tends to go out causing creaks? Its in the front and I have no clue what it is, i replaced the struts because they were already bad looking. I thought it was a cv axle because the bearing kinda got pulled out ( noticed while doing struts). Could it be the engine mounts? Control arm bushings? I will try to get a sound clip soon.
Old Mar 23, 2021 | 01:09 AM
DaIll1's Avatar
Have you gone here? https://www.acurazine.com/how-tos/a/...c-guide-426251
And lubricate the sway bar bushings, preferably graphite.
Old Mar 23, 2021 | 11:02 AM
Tomtwtwtw's Avatar
2nd on the sway bar bushings. Those can get very noisy as they dry out / wear out.
Old Mar 23, 2021 | 04:29 PM
I'll grease the bushings and check the a arm bushings as well, I just replaced the sway bar end links and bushings a year and a half ago.
will update with anything new. Thanks for the input.
Old Mar 23, 2021 | 04:37 PM
are those new OEM struts?
Old Mar 29, 2021 | 04:54 PM
No they are not. I bought them off Amazon and everything bolts up just fine, no issues but after cv axle and strut replacement I need to get an alignment. I just checked a arm bushings and they still look good. I didn't see any major damage/tears, I re greased the sway bar bushings as well. I will get an alignment tomorrow and see if the noise changes.
Old Mar 29, 2021 | 06:46 PM
What brand are they?
Old Mar 29, 2021 | 06:49 PM
Anpart.
Old Mar 29, 2021 | 06:53 PM
Ahhh no name struts huh.. hopefully they last a long while for you.. I'd be hesitant to install crap like that on such a crucial component of my car like the suspension..
Personally would have gone with KYBs from https://www.rockauto.com/en/catalog/...+absorber,7556 https://www.rockauto.com/en/catalog/...rut+mount,7600
and transferred the existing springs over myself.
Or even the Monroe kit https://www.rockauto.com/en/moreinfo...912&cc=1502807 if i was feeling lazy and didn't want to OE quality and didn't want to bother porting the springs over.
Old Mar 29, 2021 | 06:54 PM
DaIll1's Avatar
Anpart.
How much lower is it? they look a couple inches shorter
Old Mar 29, 2021 | 08:05 PM
Not much but the old ones were completely ruined, it still has a bad clunking. I'm hoping an alignment helps. It started a year ago and nothing I've done helped.
freerj
Mar 25, 2021 12:24 PM
crxzcracer
Mar 17, 2015 12:04 PM
TLGirl0090
Mar 11, 2015 08:29 PM
gentrysd
Jan 29, 2013 08:19 PM
E_dog
Mar 7, 2006 08:39 AM
