Need help locating the IAT Sensor
Old Jun 4, 2007 | 09:21 PM
RDX Lovr's Avatar
From '04 TL to '07 RDX
Can anyone tell me where to find the Intake Air Temperature (IAT) Sensor? It may also be called the AIT ot MAT sensor.
Old Jun 6, 2007 | 11:10 PM
RDX Lovr's Avatar
Seems like its the five wire sensor located at the Air intake manifold. I wont be messing with that. Wanted to add a performance module. Decided against it.
Old Jun 6, 2007 | 11:58 PM
sasair's Avatar
There are two IAT sensors. The one with the five wire harness is a MAF sensor and IAT sensor. Thus the 5 wires. The two wires for the IAT there are green/yellow and red/yellow, or pins 1 and 2 in the connector.
The other IAT sensor is below and in front of the charge air cooler cover. This one has 2 wires. also Green/yellow and red/yellow.
Old Jun 10, 2007 | 06:33 PM
Go90go's Avatar
大日本帝国
HAHAHA @ "performance" module! Tuned by eBay I see... A little resistor to trick the ECU into thinking the air temperature is colder/denser so it sends more fuel.
~Cheers~
Old Jun 12, 2007 | 06:23 PM
Force-Fed_RDX's Avatar
Former Sponsor
~Cheers~
Although those things do work, doing so on a car without a wideband would make me nerrrrrvous
To the original poster, if you're looking for a quick performance upgrade, try a manual boost controller. Just remember that more is not necessarily better when adjusting boost pressure!
Old Jun 12, 2007 | 06:42 PM
Ron A's Avatar
Administrator
I will be sending you an email about your other thread, which I deleted. Please watch for it.
Old Jun 12, 2007 | 06:56 PM
Former Sponsor
Okay, will do!
Jul 16, 2017 07:33 AM
RobbDizzle
Oct 15, 2015 11:16 AM
hrothgar02
Sep 28, 2015 11:08 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
