Maintenace question
Maintenace question
We bought RDX 08, I was wondering what kind of maintenance needs to be done? I own Acura 2001 CLS, and all I ever did is change fluids and filters and rotate tires (soon will need a timing belt).
Is it pretty much the same kind of stuff for RDX? I know dealers are trying to sell package deals which include things like (check, inspect). Would it be OK to tell them only to replace fluids/filters that are necessary?
Your the one telling them to do it and your the one paying.
it's fine.
But if I were you, since it is a 2nd yr car, i'd follow the book so far.
or read the forums on here and ask around.
IF u f33l like that's all u need, then so be it.
good luck man.
it's fine.
good luck man.
The on-board maintenance reminder will recommend the type of maintenance. Most frequent (depending on your driving anywhere between 3500 to 6000 miles) is the oil and filter change.
I would think that would be your call, as NYjumpman suggests. I come from an airplane maintenance background and I tend to follow manufacturer's recommendations. You could do the checks yourself, too. Just be sure to reset the maintenance minder 'B' indication for checks/inspections so that it won't show until the next cycle.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
