Low Fuel Warning
Old Oct 23, 2008 | 03:46 PM
spoonfed's Avatar
Exclamation Low Fuel Warning
Can anyone let me know at what point your Low Fuel Warning comes on?
We did a test yesterday and found that the warning came on with a range of 35KM (about 22 miles) remaining.
This seems like the warning comes on when it might be too late. This may be fine in the city but what if we were on the highway?
I understand that you should never let it go this low and should always keep track of your fuel level and other fluid levels but it was a test to see if the warning even works.
We also own a 2006 TSX and could swear that the light comes on around 75KM (about 46 miles). We are going to test it again though.
What have you guys seen or remember seeing?
Old Oct 23, 2008 | 07:56 PM
wrestrepo's Avatar
StayAtHomeDad
I think that what you should consider is the amount of fuel left in the tank, not how many miles you can drive on it....meaning, that you probably have the same for both cars (maybe not), but you get a lot more miles per gallon in the TSX.....
Old Oct 23, 2008 | 09:05 PM
Syzygy's Avatar
In my TL, I could drive almost 100 km after the light came on, but didn't often push it past 50 km. In the RDX, I think my light usually comes on when the range is 35 km. But, today, for example, I filled up and my light came on just a couple blocks from the gas station. I squeezed 58 litres into it. I would think, then, that you could get around 75 km after the light comes on, especially on the highway.
Old Oct 23, 2008 | 10:49 PM
ShadowGirl's Avatar
I do mostly city driving, and my low fuel indicator comes on fairly consistently when the range shows 50-60kms. Out of habit I always reset my odometer when I fill up, and it seems that I've usually driven about 520 kms by the time the fuel indicator comes on. Hope that helps!
Old Oct 24, 2008 | 08:07 AM
atlacura's Avatar
The low fuel warning in the TSX comes on much sooner (I think it was around 4 or 5 gallons in my 04 TSX 5AT) than in the RDX (closer to 2 gallons left). The miles left is computed based on recent mpg and I have found that to be a little conservative. I haven't chanced it but some other threads on here mention going past 0 miles left. Hope this helps
Old Oct 24, 2008 | 09:37 AM
neo1738's Avatar
2016 MDX Adv/SHAWD
low fuel indidcater and i believe your MID range do NOT count the 1.8gallon reserve in your tank. someone correct me if i'm wrong on this
Old Oct 24, 2008 | 10:18 AM
sasair's Avatar
Mine comes on consistently right at 25 miles left. Every once and a while at 24 miles left. But I have driven mine for over 5 miles after reaching zero also.
Old Oct 24, 2008 | 03:33 PM
phoward_15's Avatar
The mileage will depend on how fast you're going as you're looking at MPGs. So it won't always come on at the same "Range" of miles left.
Old Oct 25, 2008 | 11:56 AM
Rexorg's Avatar
It seems all Acuras have the light come on with about 2 gallons left. That is a good time to fill up as trying to push it will get into the water that is in the tank from condensation, etc. The zinc additive in the gas lubricates the fuel pump. Water is not a good lubricant. A gas and water mixture will heat up the fuel pump and possibly burn it up. In the old days you would put some gas dry in and that would mix (absorb) the water and burn it off. Nowadays, if you use a gasoline with alcohol in it will have the same effect.
Old Oct 25, 2008 | 03:59 PM
vrflyer's Avatar
That's about the same for me...
Old Oct 26, 2008 | 01:33 PM
Carbon2008RDX's Avatar
Carbon Bronze Pearl 2008
The RDX owners manuel states the low fuel indicator comes on when about 2.5 gallons (9.5 liters) of fuel remain in the tank. It also states there is a small reserve of fuel remaining in the tank when on empty.
Old Oct 26, 2008 | 02:33 PM
wspy's Avatar
2008 Acura RDX
My RDX ran out of gas 15 miles after the light came on!
Old Oct 26, 2008 | 03:09 PM
Were you by chance going up or down a steep hill/road where the remaining fuel in the tank may have not been usable do to the angle of the vehicle? Only 15 miles seems pretty rediculous after the light came on..
Old Oct 26, 2008 | 06:26 PM
chipmunk's Avatar
I personally try not to get under 30 miles left. It's just a psychological thing for me.
Old Oct 28, 2008 | 01:23 PM
spoonfed's Avatar
Good to know. I'm sure you'll all agree that it could be set higher. Why does it have to be so low?
I know it cold get annoying for it to come on at the 50 km's remaining mark but it's fuel for **** sake. We all need it.
Old Oct 30, 2008 | 07:24 AM
wspy's Avatar
2008 Acura RDX
Pretty rediculous is correct, imagine how surprized and pissed i was when it occured. The vehicle was on a very slight incline and only had a few hundred miles on the clock so the engine was not broken in yet. There was an issue with the fueling at the time but i seriously doubt that it had anything to do with when the light comes on.
Check out the ordeal here;https://acurazine.com/forums/1g-rdx-problems-fixes-160/gas-guage-tank-problem-682717/
Old Nov 6, 2008 | 02:07 PM
mmfamily's Avatar
9th Gear
I've driven more than 30 miles after the light came on...several times. Oops, there are just places you shouldn't get off the freeway in LA!
08KBP_VA
Oct 22, 2019 01:55 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
Rcelestino93
Sep 23, 2015 10:01 PM
