LED tails?
Old Mar 29, 2006 | 02:17 PM
sathiele's Avatar
LED tails?
when you go to acura's RDX site, and click on the gallery, the bottom right photo appears to be of LED tails. at least the left of the two lights appears to have LEDs behind it, but the lenses are distorted so it's hard to tell. anyone who's seen it in person know? or has it already been widely accepted that there are definitely LEDs on this ride?
Old Mar 29, 2006 | 02:34 PM
thorium's Avatar
I think everything so far (including prototype shown) has had LED
Old Mar 29, 2006 | 03:27 PM
Count Blah's Avatar
'12 TL (prev '04 TSX 6MT)
What's the big deal with LED tail lights? Appearance?
Old Mar 29, 2006 | 04:47 PM
thorium's Avatar
Not sure on looks, but I think they will last longer than a normal bulb, so you probably won't ever have to replace it during the life of the car.
Old Mar 29, 2006 | 04:50 PM
loulinjai's Avatar
Probaly (just by guess) Tails will be LED, blinkers will not
Old Mar 29, 2006 | 06:47 PM
finishline's Avatar
I think they've shown them to be more effective at what they are designed to do-- catch the eye of the driver behind you. Anyone?
Old Mar 29, 2006 | 07:04 PM
TorontoTL's Avatar
I personally really like the look of the LED's. They are really bright and they have a faster response time as well. And as mentioned they do last much much longer than incandescant bulbs so you won't have to change a burnt out bulb. I hope Acura does use the LED's for the RDX.
Old Mar 29, 2006 | 07:29 PM
Rocket_man's Avatar
Summer is Coming
Some are too bright for me, especially at night. I have no problem seeing incandescant bulbs. They do light a fraction of a second faster but that is so minor that I don't think it is a real world advantage. Yes they last longer, but good luck replacing one if it does fail. On hybrids, LEDs use less power, so that can be an advantage on a car running on batteries. The real thing is purely looks and the fad appeal.
Old Mar 29, 2006 | 09:36 PM
thorium's Avatar
LEDs have a proven track record of reliability. LED as a lighting source has a very low failure rate compared to other lighting sources (i.e., used in emergency exit signs) . They can just make LEDs bigger nowadays. They last like a decade (of continuous use).
There are other benefits to them as well, as a car designer you don't need as deep of light cavity. An incandescent bulb sticks out more, LEDs can be flat.
Old Mar 29, 2006 | 09:52 PM
Colin's Avatar
I'll be the first to admit that I don't see as well as I used to at night. I'm glad that my LEDs are brighter just in case someone like me is following my car..... IMO they are added value to many customers so I welcome them.
Old Mar 29, 2006 | 11:25 PM
rdxsteverino's Avatar
rdxsteverino
The perimeter of the tails may be LEDs but the center appears too diffuse and appears to be incandescent.
Old Mar 30, 2006 | 03:22 PM
TorontoTL's Avatar
The prototype really looks like it has incandescent lighting at the rear. Hopefully the production model will sport LED's.
Old Mar 30, 2006 | 03:44 PM
montyburnz's Avatar
They do not look like LED lights. I'm guessing they're reserving LEDs for the MDX, TL, and RL. And giving the RDX and TSX regular tail lights.
Old Mar 30, 2006 | 09:46 PM
phile's Avatar
Pinky all stinky
They don't appear like LEDs to me either. But note that the front headlights aren't production ready either. I doubt we'll see that bluish surround on the projectors.
Old Nov 5, 2006 | 01:59 PM
crazymjb's Avatar
Acura ended up skimping on the LED tails right? Does anyone know of an LED replacment for the incandescents(if they are in use)? Sure you won't get the notable LED layout, but I like the clean response of the brake lights.
Mike
Old Nov 5, 2006 | 03:22 PM
ROOR's Avatar
by putting in led bulbs u can burn out the switch and poof, no more tails
Old Nov 5, 2006 | 03:45 PM
crazymjb's Avatar
LED's consume much less power than incandescents so I find that highly unlikely.
Mike
Old Nov 5, 2006 | 05:23 PM
ROOR's Avatar
i did it in my van - it blew out the switch - the consume less, but where does the remainder go? i dont know much about electronics, and can only tell you what i know from experience
Old Nov 5, 2006 | 05:49 PM
crazymjb's Avatar
The failure of the switch was likely a coincidence.
They consume less and the remainder stays in the charging/battery system where it is either stored or diverted to other systems.
Mike
Old Nov 5, 2006 | 06:48 PM
c_hunter's Avatar
07 RDX - Royal Blue/Ebony
Did you also add a resistor to each LED? If not, then you would have shorted out the circuit, as the LEDs themselves don't provide a resistance, and would have resulted in a super-high (near infinite) current. You absolutely must add resistors with LEDs.
Old Nov 5, 2006 | 07:10 PM
crazymjb's Avatar
Excellent point. Sorry.
Mike
Old Nov 6, 2006 | 11:38 AM
ROOR's Avatar
see - thats why im an idiot - i put resistors on the turn signal LEDs but not on the rear lights. ended up that my switch blew, the brake lights worked but the parking lights were gone, had to change the switch - my poor van... i changed the switch after the first ticket i got, i could get away with driving on the highway because i would press the remote start button on my compustar and they would come on, i would have to do it over again once i hit the break, it was a pain in the ass, but a lesson as well... no need to apologize - we all learn something new everyday hehe, peace
Old Jun 23, 2007 | 02:23 PM
brizey's Avatar
Good LED replacements have the resistance built in.
Old Jun 23, 2007 | 03:15 PM
voigt's Avatar
Infiniti had an ad in C&D that said the reason why all their cars have LED's is because they light up a fraction of a second faster, witch they said results in the driver hitting the brakes faster. They gave a 16ft stopping advantage to the car behind at HWY speeds. But its and ad, take what you want from it.
Old Jun 23, 2007 | 04:05 PM
Jack Bauer's Avatar
So, has anybody replaced with LEDs lately? Any good sources?
Old Jun 23, 2007 | 04:23 PM
CoquiTSX's Avatar
I have the 15 led from superbrightleds on my TSX for 1.5 yrs. No blown switch yet.
Old Jun 23, 2007 | 04:27 PM
CoquiTSX's Avatar
As far as I know, the resistor is for the signals lights only. That way the electrical system senses the resistance and lights does blink faster.
Old Jun 23, 2007 | 04:43 PM
brizey's Avatar
I did my license plate lights (baby steps!!!) last night with superbright led's. It was easy to do and they look cool.
I'm going to do the courtesy lights and interior lights at some point as well.
Old Jun 27, 2007 | 11:03 PM
brizey's Avatar
I did all the interior lights. I used:
WLED-WHP Pure White High Power
from SuperBrightLEDs for the courtesy lights, map lights, and cargo light (and the license plate lights)
and
3022-x9 LED Festoon bulb
from the same place for the main interior light. I love the look.
BTW, I think the 9 LED is bright enough. It is not as bright as the original bulb, but it is ok, and it matches the others.
I think the map lights are brighter than the stock bulb. Same with the courtesy and license light.
Old Sep 1, 2007 | 10:17 PM
JMJ3rd's Avatar
'06 RL Tech
If you are buying your replacements online, would you point me to where, please. I want to do the plate, and interiors as well.
Old Sep 1, 2007 | 10:38 PM
k23a1's Avatar
http://www.superbrightleds.com/1157.htm
Old Sep 15, 2007 | 12:38 PM
brizey's Avatar
BTW, the LED's have been in for a few months now with no issues.
CL-S progression 01
Jan 26, 2016 04:15 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
eastcoastguy
Sep 23, 2015 06:29 AM
