How to replace door's arm rest
The door handle leather (arm rest area only) is showing signs of wear, I'd like to replace it. What is involved? Does door need to be taken apart? the part is only $36
haole kama'a-ina
See this thread. When the panel is off, you can remove the armrest trim (plastic rivets I think) and replace it.
DIY - Remove Door Interior Panel and Replace Speaker
thanks. Do you think for that I will need to detach inner latch release you mention:
When the door panel is free, hold it a few inches away from the door and use needle-nose pliers to release the 4 spring clips holding the inner latch release to the panel. Gently let the latch and cables hang free.
mada51589
05-03-2022 08:54 PM
handsom-hustla
11-13-2015 05:04 PM
