How much damage can be caused by improper tow?
What do you guys think would be the extent of damage on an improper tow on a SH-AWD system. By improper I mean two wheels on the dolly, car in park and two wheels rolling on the ground. 5 mile distance, speed would at most go up to 40MPH.
Would damage be in the transfer case and/or transmission only, or does the differential sustain damage first or at all. For some reason it doesn't make sense to me that differential could sustain any damage since its made to spin anyway.
I also read that rear wheels are designed to be overdriven with respect to the front wheels. I wonder if this would protect the differential in case of an improper tow since the front wheels would not be spinning.
I would love to hear everyone's opinion or experience with this. All manufacturers have different AWD systems and from research certain ones are more sensitive than others.
Why the questions? if you have not already done this, then you know that the Owner Manual says flat-bed tow only, i.e., entire vehicle on the back of a flat bed truck. So why ask "how" any damage could occur? the OM says it can.
If you already did this, then you need to have the vehicle checked by a dealer. Esp. if the vehicle was in park, with the rear wheels on the ground, probably the entire drive train is subject to damage. A tow truck operator should know better, but then, they can't keep track of every vehicle made - its your responsibility to know about your own car.
Sorry, I hope that your vehicle is not damaged - but suggest that you have it checked.
Originally Posted by nedomedo
...rear wheels are designed to be overdriven with respect to the front wheels. I wonder if this would protect the differential in case of an improper tow since the front wheels would not be spinning.
If there is damage, it is probably in the SH-AWD overdrive unit, which connects the rear diff to the rear prop-shaft.
Let us know if you get a fault code or have damage.
This is the worst possible towing configuration. The rear prop-shaft will be unable to rotate, because the parking pawl has locked the transmission.
Because the rear prop-shaft cannot rotate, the damage should be contained within the rear differential. The left/right clutches may take some wear, but can probably survive 5 miles.
Basically I am getting rough shifts when driving, the code I get is P0962 - ACURA - A/T clutch pressure control solenoid valve A (short)
So I am hoping its only the solenoids since my symptoms match the problem. The only thing that worries me is that my paddle shifters are not working at all. I wonder if the solenoids will fix that also? I was doing some research and it said that certain car makers have a fail safe security system to protect the transmission. The computer turns "off" the solenoids to prevent transmission going bad due to a number of things. I wonder if this is possible.
I am also getting some ABS codes, but I am waiting for a friend to put it on his Autel MaxiDAS diagnostics computer to get more info on that. I believe the ABS codes are referring to one of the speed sensors being out.
Tranny doesn't slip, only shifts late and snaps your head back when shifting. I visually inspected the rear differential and brakes and everything is perfect. The SH-AWD is performing according to the instrument screen. I do have a check transmission and flashing D.
I can make the repairs myself with my friend (retired mechanic) but just trying to figure if I should replace the solenoids or the entire transmission. And my main worry is the rear differential, even though everything seems normal with it. I can purchase a used differential for $500.00 which is way better than 3+k at Acura lol.
Thanks any advise is appreciated.
The flashing "D" indicates that there is a transmission fault code stored, but of course you already know that.
If it were mine, I would fix the trans solenoids and ABS items. Address and clear the fault codes and see how it goes.
If the SH-AWD screen shows normal operation and there are no system fault codes, you may be ok.
Well, there is nothing to "visually" check on the SH-AWD unit, without opening the cases, although I suppose you can check for any external damage. Perhaps fix all trans errors and other errors, then see if the SH-AWD unit reports any errors.
This is why I only allow my car to be loaded in my presence - but you will know for next time.
Does PARK still work? that is, does the trans still lock in PARK, which would indicate that the parking pawl is OK.
Both the solenoids and pressure switches can be electrically tested. The pressure switches control the solenoids. The specs are in the FSM.
That would be a result of the failed solenoid(s). Continuing to drive will (further) damage the trans. When the solenoids are bad/ failed, the trans goes into limp mode, and ups the system pressure. I am not a trans mechanic or "expert" by any means, but it is pretty clear from many posts that a trans should not be driven under these conditions.
Would you order oem only solenoid? it's a big price difference.
I would use the OEM parts its not cheap but remember you pay for quality. once the vehicle is up and running id change the fluids and filters if present associated with the transmission the SHawd and the rear diff. pay close attention to see if there is any chunks in the fluid (bad news) also id stick a magnet in the fluid stream to see if there is suspended steel partials in the various fluids. as far as the transmission going into limp mode it should be fine after the new solenoid is replaced. as long as the fluid was ok. one thing I do know is that when transmissions have nice soft shifts it is harder on them then when its a firm shift hence why shift kits tend to jerk the passengers around more but the transmissions last longer (at stock power levels). good luck with everything and keep us in the loop.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
