Help!! Having AC and battery problems
Old Apr 8, 2021 | 04:02 PM
Tdeezy's Avatar
3rd Gear
I have a 2008 rdx tech package...Im having battery problems and AC problems first the battery issue
I had to jump the battery 3 times this week when it sits over 4hrs, I had AAA replace the battery today but sometime is still draining the battery im wondering if it has to do with my AC issue...AC issue is its blow cold on the passenger side n hot on driver side...Im replacing the blend door actuator to see if that helps but about 5 days ago when traveling to plam springs my AC was smoking or maybe the belt idk but it doesn't do it now, then that's when the battery issue started after that happened, I have no CEL car runs good.. I notice today that it spatter a little bit on idle
Any help is greatly appreciated
Old Apr 8, 2021 | 05:15 PM
could be the bluetooth module.
Old Apr 8, 2021 | 06:10 PM
csmeance's Avatar
sounds like your A/C clutch has melted or burnt up and is not allowing the alternator to charge the battery. It could also be a stuck AC relay keeping power onto the compressor. Smoke from A/C system is never good. Usually when system is low on refrigerant it will cause the issue with driver side warm and pass cold.
Old Apr 8, 2021 | 07:20 PM
Tdeezy's Avatar
3rd Gear
the smoke came from the engine bay where the belts and ac compressor is..ima check the ac reley too thanks
Old Apr 8, 2021 | 07:22 PM
Tdeezy's Avatar
3rd Gear
I disconnected the module box on the passenger side..still had problems
Old Apr 10, 2021 | 08:11 AM
russianDude's Avatar
I noticed he was over the factory warranty, was this covered under power train warranty or extended warranty?
Old Apr 10, 2021 | 08:18 AM
Old Apr 10, 2021 | 08:27 AM
sorry, wrong post
Sarlacc
Jun 7, 2021 07:09 PM
Polysafe
May 30, 2020 06:59 PM
mzilvar
Jan 13, 2019 04:06 AM
TIFFANI25
Jul 22, 2013 07:08 PM
max1995
Aug 8, 2012 01:36 PM
