headlight question
Old Mar 19, 2007 | 07:40 PM
mickie's Avatar
headlight question
Just checking to see if my headlights are out of allignment. When I pull the car up to my garage with the doors closed, the driver's side is higher then the passenger's side on high beam. But on low beam, the "light line" is askew (lower on the passenger side.) Not a straight line.
Old Mar 19, 2007 | 10:12 PM
rdxsteverino's Avatar
rdxsteverino
For the HIDs, the uneven light line is normal. It designed into each HID lamp to keep glare down for oncoming traffic. See the discussion in the following thread:
Uneven HID Light Profile
There is a vertical adjustment for the HIDs, but it moves the entire uneven light line together for each lamp. Not sure about the high beams - I would guess they have one too.
Old Mar 20, 2007 | 08:07 AM
catnippants's Avatar
Hmmm....Mickie's does sound out of alignment to me. I was told about the uneven line when I bought the car - but I thought it was supposed to be higher on the PASSENGER'S side. The idea being that you light more of the road in front of you and minimize blinding cars in the oncoming lane. Maybe I'm wrong?
Mike
Old Mar 20, 2007 | 08:54 AM
phoju's Avatar
phoju
for hid's one side is gonna be taller then the other...
Old Mar 20, 2007 | 01:21 PM
flar's Avatar
Former 07 RDX Tech owner
Yes, the driver's side should be lit lower than the passenger's side, not the other way around. And each light should have a "jaggy" in its horizontal cutoff, kind of like this:
Code:
        ________
_______/
Old Mar 20, 2007 | 04:40 PM
sasair's Avatar
your highbeams should be even with each other. the low beam HIDs should appear with a cutoff line just like flar drew.
Old Mar 20, 2007 | 07:58 PM
mickie's Avatar
Oh thanks, yes, Mike and Flar, I ment to say they were higher on the passenger's side with low beams. I never noticed that until recently. You guys are awesome, thanks so much. I was really worried that I had to replace the passenger's lamp, or have that all reset.
It looks just like you spelled it out flar.
Old Mar 20, 2007 | 08:50 PM
Yeah....I gotta say, I have mixed feelings about the HIDs. This is my first set, and while the brightness, color and clarity are AWESOME, that hard line is extremely disturbing and hard to get used to. At least with halogens there's some flood effect and the light fades out slowly. With the HIDs, I always feel like I'm overdriving them...
Mike
Old Mar 20, 2007 | 09:40 PM
Texas's Avatar
^^^ Yes, Plus on rolling or undulating roads, people are prone to flash you thinking your lights are on high beam…as it is bright to them as the road has caused your low beam to appear as a high setting would…
Old Mar 21, 2007 | 03:28 AM
flar's Avatar
A lot of the higher end cars pair HIDs with an auto-leveling feature that keeps them from popping up. Some are slow and only really help if you've packed a heavy trunk on a trip. Others are a little faster, but I'm not sure even the fastest really can deal with cresting a hill or hitting a bump. The RDX has no auto-leveling feature.
Another factor going against the RDX wrt HIDs is that it is an SUV and so the headlamps sit higher off the ground. To keep them from shining in anyone's eyes they have to have a fairly aggressive downward tilt. You can see this on the center concrete divider on a highway at night if you have such things on your highways. Otherwise, drive up parallel to a building some night and see how the cutoff line hits the wall. It will definitely slope towards the ground so it doesn't take much to over-drive the low beams.
Old Mar 27, 2007 | 06:30 PM
chyllintsx's Avatar
Missin my TSX =(
if u ever need to get a new headlight let me know. .. ill buy ur old one... good broken or watever
BoricuaTL
Apr 8, 2016 01:08 PM
pistacio
Sep 26, 2015 09:45 AM
eastcoastguy
Sep 24, 2015 02:07 PM
datadr
Sep 12, 2015 09:12 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
