Fuel Gauge doesn't work
Old Jun 10, 2020 | 07:40 PM
Dominik W's Avatar
5th Gear
Thumbs down Fuel Gauge doesn't work
So we were driving, and our car suddenly stopped working. Apparently we ran out of fuel. The gauge, however, showed that we still had some fuel left. What could the problem be?
Thanks for any help.
(We have been managing refueling, we set up a schedule)
Old Jun 10, 2020 | 09:10 PM
How many gallons did you fill up after the fact
Old Jun 11, 2020 | 11:16 AM
Tomtwtwtw's Avatar
Are you sure it's the gauge and not, say, a bad fuel pump? Unless you've since re-filled and are driving fine, in which case disregard.
Unfortunately there are a number of things that can affect the operation of the gauge. Common ones could be a bad fuse or a stuck float. If the needle moves when you start/stop your car, the fuse should be fine. If the gauge is stuck somewhere in the middle when you know there is more or less gas in there, then you may want to look into the float or the sending unit of the tank. Could even be the gauge cluster itself, although I think that's extremely rare.
Eggs999bacon
Jun 18, 2018 08:18 AM
timberland73
Aug 4, 2010 02:39 PM
nkafeel
Mar 21, 2010 06:50 PM
rchuang
1G TL (1996-1998)
22
Sep 25, 2005 02:53 PM
aznboyz2000
Jan 14, 2002 03:48 AM
