Exhaust System
Old Jun 10, 2020 | 11:36 AM
TECoo9's Avatar
Question Exhaust System
Got a new prob with my 1GEN RDX, getting a rattling, ticking noise when i let me foot off the gas, coming from the area of the first catalytic converter, took it to a mechanic and he told me the gasket is bad, What is the name of the gasket between the cat and the manifold?
Old Jun 10, 2020 | 11:41 AM
Tomtwtwtw's Avatar
Get a 2nd opinion. Usually the off-throttle rattle is a sign of the actuator bolt wearing out. You can also take a peek at it yourself - it would be visible from just popping the hood. Assuming it is the bolt, most likely within the next few months you'll throw a P2263 code.
Below is a link showing some video of a worn bolt in action, but the whole thread is full of good info.
https://acurazine.com/forums/1g-rdx-.../#post15895728
Old Jun 10, 2020 | 02:22 PM
Could also be the heat shield, make sure that's not loose/rusted off. did he take off the exhaust to examine the gasket?? https://www.oemacuraparts.com/v-2010...t-pipe-muffler gaskets could be found here if that is indeed the culprit.
Old Jun 11, 2020 | 10:50 PM
CSmoney28's Avatar
CSmoney28
I had to change my catalytic converters heat shield upper and lower for the same reason. Waste of money the noise went away but then I went atlp and rv-6.
scotts97CL2.2
1G CL DIY & FAQ
Jun 9, 2009 10:13 AM
blktsx23
1G TSX Problems & Fixes
Aug 23, 2007 05:38 AM
Acura2.3CL
Aug 1, 2005 05:05 PM
powderman
Jan 28, 2005 02:22 PM
