Front Pads/Rotor replacement
Old Aug 9, 2010 | 11:53 AM
gsvette's Avatar
Does anyone have suggestions on where to purchase pads and rotors for my 2008 RDX?
Local Dealers are pretty pricey.
Just came up on 28000 miles and am getting a grind on drivers side when stopping hard.
Also seems to have a little fade now as well as slight vibration when stopping from well uh high speeds
Pads still have a bit more material left in them but I don't want to take any chances.
Second question is there a better pad and rotor combo for not a huge amount of coin for the aggressive street driver?
Old Aug 9, 2010 | 03:32 PM
R*D*X*'s Avatar
https://acurazine.com/forums/1g-rdx-2007-2012-147/ebc-redstuff-pads-usr-series-rotors-anyone-running-these-780648/
Old Aug 11, 2010 | 09:21 AM
gsvette's Avatar
Thanks R*D*X*, looks like there are not a lot of options for rotors. I tried purchasing EBC slotted rotors but they were not in stock. Plus I don't trust drilled or slotted rotors as I have seen aftermarket ones crack (albeit on Corvettes not on the RDX).
I did not want OEM because the Rotors did not last as long as they should have!
So I bought Centric 120.40073 Cryo rotors and Centric 105.10890 ceramic pads.
Hopefully they will be a bit better than stock.
Old Aug 11, 2010 | 10:52 AM
Scottieb's Avatar
I have the same issues, with 34K. I think this is way too soon for pad, and rotor issues. I am going to the dealer on Friday, and I will not let them charge me full price if there is an issue which there should not be at 34K!
Old Aug 20, 2010 | 09:36 PM
pdpgps's Avatar
Centric rotors and green stuff pads. Good combo. Significant improvement at a reasonable cost. I just ordered stainless steel brake lines so I'll be throwin those on the RDX soon. I"ll let you know how that goes.
csmeance
Jan 7, 2026 06:25 PM
08 NBP TL
Sep 8, 2015 08:49 PM
RK_AcuraTL
Sep 5, 2015 02:26 AM
asahrts
Sep 4, 2015 05:55 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
