DRL Mod, Parking Lamp LEDs
Old 05-19-2017, 07:47 PM
4th Gear
Madrvr's Avatar
I had enough of the highbeam DRL. This is what the factory should have done, though in 2008 LEDs were not so common.
(Sorry for the poor video. I will shoot it in HD next weekend.)
This mod is totally revesable in 10 minutes. NO factory wires were cut. I could have used the incandescent amber bulbs but I wanted white LED DRLs.
I used:
Switchback LEDs
Male sockets from eBay
Female OEM sockets from junkyard
Diodes
Load resistors
Relay
Fuse tap
I will post more details if some are interested.
The following 2 users liked this post by Madrvr:
mrgold35 (05-31-2017), TheWrench116 (05-21-2017)
Old 05-21-2017, 11:21 AM
FLETCH
TheWrench116's Avatar
good looking mod. post a diagram if you would.
Old 05-22-2017, 11:48 AM
Tomtwtwtw's Avatar
Agreed, I would love to try something like this in the car. Very modern touch to a car whose design is basically a decade old now, but still has many years of life left.
Old 05-28-2017, 10:34 PM
Kevin125's Avatar
Nice mod. I almost went the same route but instead I changed the high beams out with 3000k bulbs and put switchback leds in. So during the day it is yellow for the daytime running lights and led white for the park lights. I will run the fog lights to work with the drl so it stays on all the time
Old 06-05-2017, 11:44 AM
eaglesfan398's Avatar
Would love a guide on how to install this thanks!
Old 06-05-2017, 09:28 PM
Found these online any thoughts? How would I disable the stock drl's when these are installed but still allow the high beams to work?
https://www.superbrightleds.com/more...ofit-car/1778/
Old 06-07-2017, 09:41 AM
2008 Acura RDX
wspy's Avatar
Wink
Pull the DRL fuse is all.
Old 10-29-2017, 10:41 PM
Kevin125's Avatar
Please most more information on the mod. I would like to know. I would definitely do this to my RDX
Old 10-30-2017, 03:34 PM
schen72's Avatar
What happens to the signal lights? Now you have white "always-on" signals. Does this mean you no longer have signal lights in the front?
Old 12-06-2017, 08:17 AM
Go Stros!
I would be interested to see the plug in play wiring diagram.
Old 12-11-2017, 06:43 PM
WTF?
bluecarbonfiber's Avatar
its more than just pulling the DRL fuse.. if youre high beams are on your low beams are off. so he ended up changing something in the wiring too
