Driver Outside Mirror
Does anyone have a problem with the driver side mirror not extending out far enough to see vehicles to your left? The dealer I questioned about the problem said that several other RDX owners have also complained.
WayTooManyAcuras
I always put the little spot mirrors on every car I buy. I had those on my RDX before I got home with the car from the dealership. I think they're worth their weight in gold!
Missin my TSX =(
big enough for me... just lean up a little... its not supposed to show u the blind spot... thats y its called a blind spot... get one of them little mirrors... blind spot mirrors..
Where did you put the spot, top bottom, right, left?
I agree there is a bit of a blind spot
to prevent blind spot
Originally Posted by hokietl
I put the round convex mirror on the bottom outer edge of side view mirror
I feel blind if I drive a car without the stick-on convex mirrors. Get the biggest one that fits and place it as far out as you can. You will need to learn how to use them as cars seem much smaller in them. But you can see EVERYTHING, including the curb and anything in a blind spot.
Driver outside mirror
This is a great little wide angle which attaches to the mirror housing and blends in well. PLUS it doesn't take away from the factory mirror like the stick on's.
http://www.autobarn.net/auxwidmir.ht[/IMG]ml
Originally Posted by rdxsteverino
All recent Hondas/Acuras I've owned allow you to make a gross adjustment to the side view mirror by physically pushing it left or right into a nominal position (you'll feel detents as you adjust) then using the electronic control for fine adjustments. Have you tried this?
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
