Does dealer replace transfer case fluid when you do MID 3?
Old Nov 15, 2015 | 04:33 PM
russianDude's Avatar
Just looked at my older invoices from the dealer when I did transmission service. No where it says that they replaced transfer fluid. Just says DW-1 3 qt for ATF and washer. I asked service advisor, and he claimed that when you get "3 - transmission fluid change", they always change transfer fluid together, except I don't see it in the detailed invoice. Did anyone check if your dealer indeed replaces transfer fluid when you come for "3" MID ?
Old Nov 15, 2015 | 06:39 PM
mrgold35's Avatar
mrgold35
My dealership always does trans+transfer case with the "3" service since they both take the same type of oil. I really don't look at the receipt to double-check; but, that is the company line when I ask.
Old Nov 15, 2015 | 07:44 PM
The transfer fluid is not the same fluid, you can find it on this forum. Only needs 0.5qt of it. Does your dealer service invoice shows it being changed?
Old Nov 15, 2015 | 09:31 PM
Tomtwtwtw's Avatar
I thought the transfer fluid service was a 5 or 6 on the MID?
Old Nov 16, 2015 | 05:43 AM
6 is rear differential fluid. 3 is transmission fluid and transfer case fluid.
I am pissed, I don't think mine was done, they would typically write fluid used and washer in the invoice. It's not same fluid as transmission ATF. Would be interesting to see if someone could check their service notes from dealer for #3. The funny part, they told me they do both and I trusted them.
Old Nov 16, 2015 | 09:44 AM
Tomtwtwtw's Avatar
Ah, I knew there was something AWD-related up there. I remember browsing it in my manual a while back and quickly disregarding it since I got the FWD model.
tman89544
1G RDX (2007-2012)
28
Nov 18, 2015 01:43 PM
Lanaue
Nov 15, 2015 10:13 PM
TLMichelle
1G TL (1996-1998)
Nov 15, 2015 08:20 PM
godfather18
Nov 14, 2015 03:40 PM
whttls
Nov 13, 2015 09:43 PM
