2007 rdx
Old 02-21-2018, 09:15 AM
4th Gear
Alexandria Aymelek's Avatar
2007 rdx
Hi everyone,
So it has been a long 2 days with no car. I need held. So Triple A came out and installed the new battery prior to changing the alternator and they hooked it up incorrectly (idiots) they put the negative where the positive was and vice versa. So now my car in completely dead I went to buy another NEW battery and nothing. I took a looked at the main fuse and main fuse 1 was blown replaced it and car wanted to start but each time I start it, it is blowing that same fuse. I think there is a short somewhere. Can someone elaborate if something similar has happened to them. Thanks!
Old 02-21-2018, 09:38 AM
mrgold35
mrgold35's Avatar
Received 1,532 Likes on 1,193 Posts
I would call AAA back and get them to fix your RDX. It shouldn't be your responsibility to fix if they made it worse.
Old 02-21-2018, 10:02 AM
4th Gear
I have tried to call them with no luck.
Any idea what it might be?
Old 02-21-2018, 10:05 AM
Received 16,266 Likes on 11,974 Posts
I believe a 3rd gen TL'er had to replace the whole entire fuse box...when this happened to him
Old 02-21-2018, 10:30 AM
4th Gear
Dang that sounds expensive.
Old 02-21-2018, 10:34 AM
didnt watch the vid; but maybe it's helpful to you
Old 02-21-2018, 10:35 AM
https://www.youcanic.com/jump-starte...tery-wrong-way
check ALL fuses
Old 02-21-2018, 04:46 PM
Lc46em's Avatar
Check all your fuses I would say if it cranked and wouldnt start could be fuel issue. I would start with a volt meter and test light to determine what is getting power and what isn't
S L I C K
09-25-2006 08:59 PM
S L I C K
06-16-2006 04:02 AM
Quick Reply: 2007 rdx
