2007 Acura RDX key stuck in ignition
Hello all,
I have an 07 Rdx key will not come out of ignition! I did the following already lubed the part on the back side of the ignition switch still did not work. I unplugged the green connection which I believe is the immobilizer once disconnected the key comes out. I did see posts on this site about Switch pin set in the shifter, does anyone have any info on how to replace this??
Thanks so much,
Thanks so much,
Null and proud of it
When mine did this, I had to replace the entire ignition assembly. Luckily the key came out, sometimes they have to cut it. I had my dealer do the work do I'm not sure what's involved specifically, but this is a really interesting problem the 1G RDX has.
Midnight Mystery (03-18-2022)
Megatron
08-06-2024 07:41 PM
Ryley
02-27-2016 03:47 PM
