07 RDX rear hatch
07 RDX rear hatch
The rear hatch will not open unless I crawl through the back seat, remove the tiny access panel and manually open it. Is this a dealer-fix or DIY? Any thoughts welcomed.
Chances are it's one of two things.
1. Door actuator is broken.
2. Fuse that powers the actuator has popped.
I assume the actuator is replaced through the same access panel you are using now, but I'd have to get back there and look for myself to be sure. Unfortunately I do not know which fuse it is, but I recommend starting with the interior fuse panel if you want to check. Maybe someone else can chime in and correct me on this if I'm wrong though.
mkeggers (04-06-2014)
do all the doors lock and unlock with the keyless entry?
rockyboy
08-04-2024 10:35 AM
snorf
11-04-2019 06:44 AM
