Driver Height
I went to test drive an NSX recently & altho I fit fine (I am on the short side), my friend who is 6'2" did not fit that well: his head was up against the ceiling. We adjusted the seat as much as possible but no help - the only way was to take the top off.
So, is anyone here 6'2" or taller? If so, how do you fit in your NSX?
Thanks!
Thanks!
Dali sells a small cushion to accommodate taller drivers. Also if it's an older NSX, may be a good time to get some aftermarket Recaro's or Brides. The rails will sit lower then OEM which will help.
Jul 16, 2017 07:33 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
4drviper
Sep 23, 2015 07:42 PM
