Tire Plus Size Info
Jhatt from Ludhianna
Tire Plus Size Info
Hi Guys;
My stock tire size is 205/55/16 and was woundering if I wanna increase the width of the tire without changing the rims what plus size would be good??
Some web site has recomended 205/50/17 is this correct???
Also, What are the pros and cons in doing this kind of swap.
Any info is welcome.
I know for sure that there will some kind of drop in height not sure how much though??
Thankx
JFK
Thankx
JFK
you can fit 215/60/16 for stock height no rubbing...on stock rims
if you are staying with 16 rims...205/50/17 wont work...presuming you wanna stick with 16 inch
you can try 215/50 or 225/45/6
May be I am not understanding the numbers correctly of the 205/55/16 the number 16 represents the rim size right?? and 205 outside dia and 55 inside dia on whihc the rim sits ???
AM I correct????
AM I correct????
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
The first number, 205 for example is the tread width, you can go up to 225 or so on those. That's just how much tread is on the tire. That is what I believe you are asking about width wise. The middle number 55 for example is the thickness of the tire. And the 16 is the Rim size
6spder
1 Post
/\ what he said! the width is the 205# not the 55#. i would also say, 225's would look the best. I've had 225/55's on my legend and the rims are almost the same width (if not the same) and they look perfect, and i think they would be the same on a CL.
Originally Posted by google
How To Read A Tire Size
The sidewall of a tire makes good reading - if you know how to interpret the information you'll find there. Take a look at these basic definitions.
205/55/r16 88V as an example
1. 205 Width of the tire in millimeters.
2. 55 Aspect ratio - This sidewall's height is roughly 55% of the tire's width.
3. R For radial construction
4. 16 Nominal rim diameter code of the wheel on which the tire fits.
5. 88 Load index is a numerical code associated with the maximum load a tire can carry under certain service conditions.
6. V Speed symbol - This tire can carry a specified load under specified service conditions at speeds up to 149 mph.
7. 88V Service description, a combination of the Load Index and Speed Symbol.
2600lb CL
Thank you Klepto. I was going to shim in exactly what was said on the above post. A lot of people make the mistake of thinking the the sidewall (55,60,65,etc) is the measurement of the sidewall in mm, when in fact it's a percentage of the width of the tire.
Anyways, I wouldn't go with a 60 sidewall, too much roll over during hard cornering. Also, a tire should not overlap the rim itself. For example, a rim that should carry a 205 tire on it (based on rim width), should not have a 225 tire fitted on it. Although you can do this, you end up with less thread to the ground when compared to the 205. On top of this, you decrease the overall handling performance of the car since the sidewalls aren't flat anymore, and will look more like this ->> / or \. When that happens, you decrease the speeds at which you can take turns. This is all track related, and you will NOT feel a difference when driving on the roads at normal speeds. I'm just throwing this at you because it's the proper way to go about choosing tires sizes with rim sizes.
Streched tires or overlapped tires = overall decrease of handling during track purposes.
My question is, what are you trying to do? Just want the look? Want more traction?
I would like more traction, not so much on the look. Well I dont do any track but I do drive a little bit on the harder side and do take the truns pretty sharp. I juts dont want the tires to pop off the rims when taking a sharp turn thats all. If it can hold street sharp turns then I am good.
Thankx for your feedbacks guys....
JFK
JFK
Turtle Charged, Biotcch!!
You can go with 215/50/16 slammed no problem. That's what i had on my car and my car was ~2" off the ground.
The tires overlapped a little bit but I never have problem on the street, diff on the track though...
Can I put 235/40/18 tires on my wheels with my Neuspeed Sportline 1.75f/1.5r drop with no rubbing issues? Or should I just stick with what I know.. 225/40/18?
Thanks!
Thanks!
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
