screwed by dealer?
![Angry](https://acurazine.com/forums/images/icons/icon8.gif)
Hope you guys can help me with this. I took my 1999 CL 2.3 in for an alignment on Friday. The next day, I took it in to Sears to get a free alignment check just to make sure the dealer didn't screw me. I can't afford the Helm's manual so maybe someone has a copy and they can check the alignment specs.
Here are the measurements from Sears:
Left Front Camber: -0.1 degrees ---------- Right Front Camber: -1.0 degrees
Left Front Caster: 2.5 degrees ------------ Right Front Caster: 2.6 degrees
Left Front Toe: .42 degrees ---------------- Right Front Toe: .37 degrees
Total Toe: .79 degrees
Steer Ahead: 02 degrees
Left Rear Camber: -0.8 degrees ------------ Right Rear Camber: -0.8 degrees
Left Rear Toe: .51 degrees ------------------ Right Rear Toe: .43 degrees
Total Toe: .94
Thrust Angle: 0.04 degrees
Is my CL in alignment? Thanks in advance for any help.
By the way, CL's freakin rock!
Total Toe: .94
Total Toe: .94
Total Toe: .94
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
IBankMouse
06-13-2020 12:53 PM
