plz i need advice on rims and tires
i wanna make my cl look jdm so i wanna get these rims but i dont know if i should go 16'' or 17'' . i got the car slammed to the floor and i got the 16'' factory with 205 55 16 tires but its eating my tires cuz they tell me tires are to thick and the car is 4 inch drop i just bought coil over and camber kit and thinking of putting 16'' with 215 45 16x7 offset38mm i wanna keep it slammed i need some advice im buying them this week
look like 18s to me
as for your question:
"so how did u do that to ur lights
imma try doing it to mine"
He already told you. Look up the blackhousing DIY and tint your corners.
First of all, are you putting all those links in your sentences, or is that the website being weird? Nobody will even know they are there, and you don't have to do it every time you say car or tire.
Second, please use some more punctuation just so people can follow what you say more easily and therefore help you better.
Also, you don't need to post this exact same thing in three different threads, two of which you started with this as the original post.
Anyway, I didn't know JDM CL's came with wheels like that .
But your tires are getting eaten up because they are rubbing? You could go down in wheel size, tire size, both, or raise the car some. If you are rubbing with 16s, going up to 17s would not be a good idea. You also say you are thinking of going with a lower profile tire on 16s. That would be a better idea, but damn man that is going to be funky.
i wanna make my cl look jdm so i wanna get these rims but i dont know if i should go 16'' or 17'' . i got the car slammed to the floor and i got the 16'' factory with 205 55 16 but its eating my tires cuz they tell me tires are to thick and the car is 4 inch drop i just bought coil over and camber kit and thinking of putting 16'' with 215 45 16x7 offset38mm i wanna keep it slammed i need some advice im buying them this week
CL in lawnmower status
post pics of your cl, i want to see this 4 inch drop
And i'm assuming eating tires because of rubbing since you have a camber kit and i assume if you dropped all that money on a camber kit that you would get a simple alignment.
But you can tell me if i am wrong.
Switch to a smaller size tire, 55's are quite big.
what's with people and jdm cl's? like half of the new members have jdm in their username
i should have phrased that better, i meant to say why are people calling there cl's jdm, so dumb
whenever my buddies say i'm just an import guy, i tell them how the cl was the first acura to be engineered and manufactured in North America, and that their domestic cars are probably more of an import than the cl... and then they stfu
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Check out this thread
https://acurazine.com/forums/1g-cl-photograph-gallery-57/late-night-pics-731381/
And there's no such thing as a 4" drop on a CL, your frame will be on the ground
Rockin the D2! Purple Pwr
ok, buddy...
CL come from ohio.... sorry to burst your bubble... so, we are not able to jdm it...lol
Lips don't really matter.... for size wise... it's just for looks...
if, you want to run slammed stay with a bit higher offset rims cause you will be poking and have nasty camber... either way you will have nasty camber...
correct me if, i am wrong... it might be that i'm really tired...
look through the Black market for wheels....
because it's an inch wider, that translates into half an inch more of lip, which is also about 13mm, plus you're taking away 38mm, so 38+13=51mm, 51mm/25.4mm = just over 2 inches less lip on a 16x7 +38 vs 16x8 0
and there is your math lesson for the day.
but please post a pic of you're cl i want to see if you're as slammed as you say you are
because it's an inch wider, that translates into half an inch more of lip, which is also about 13mm, plus you're taking away 38mm, so 38+13=51mm, 51mm/25.4mm = just over 2 inches less hub to outer edge of rim measurement, usually would translate directly to the size of a lip on the same design wheel on a 16x7 +38 vs 16x8 0
002's that are 16x8 +0.
501's that are 16x8 +15
These 002's are 15x7 +38. You lose a lot of lip.
What camber kit did you get? I believe the Skunk2 kit requires you to cut holes in your shock tower for clearance. This is only if you're dumped, which it sounds like you are.
so all i'm hearing is that having no camber kit is good compared to that kit
just have to deal with minimal inner tread wear (may get my tires flipped if possible), and looking good being cambered
DAMn !! WHAT should i do I COULD GET MY $200 back.What should ibuy the stock ones ?cuz mine fucked up.
CHECK THIS CAMBER KIT LOOK AT THIS LINK http://www.redlinemotive.com/store/e...-kit/acura.asp
I just got my money back. I went and bought stock upper ball joint and my lower sway bar bushing on both sides. See i bought the car wit the springs cut so now, imma put in everything new balljoints wit the 2 camber that go on the fork, Tokico shocks and skunk 2 coilovers and the rims and tires good aligment leave it at a 3 inch drop . THATS IT I MADE UP MY MINE I JUST BOUGHT EVERYTHING
merc009
10-03-2015 12:59 AM
nuldabz
09-03-2015 05:49 PM
