5 Lug Conversion
a jawful a somethin awful
Originally Posted by Cocoa
Don't bother....waste of money....
you can find the same rims, or something very simular in a four lug.
conversion costs some cheese meng..
I'm a llama :(
Why do you guys say it's a waist of money? It's all rellative. Anything can be a waste of money to certain people. But if it's something a person wants to do and that person wants to spend the money on it, then it's not a waste of money to that person.
I actually think it's not a bad idea and I've thought about it myself. All you need is the parts from an old car. How much could that be? Probably around a 100 bucks or so. Is that a lot? To some it is, but others it's not.
The reason I like the idea is because I'm a fan of factory Honda and Acura wheels. I like the factory look for my car. I want it to look like it could have been purchase new that way. The only way to upsize wheels with factory Honda wheels is to go with a 5 lug conversion.
I would personaly go with 17" Accord wheels. There's several different styles that I like. Slap some Acura Center caps on it and I'm set.
Now I've been told that you can't do the conversion with the 5 lug Accord parts or the CL/TL. You have to go with the first generation Odyssey. I'm not sure if that's fact, but that's what I heard. I don't know exactly what parts would be needed, but It can't be that hard to do. If Civic guys can do it, why can't we?
I'm a llama :(
Originally Posted by hybridnrg
yeah some people did that on there "civic's". it would open a range of rims you could put on though.
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
If you can do the conversion for about $100 or so like you say, then it doesn't seem like a real waste of money. But if the conversion ends up costing more like $500+, then it seems like a real big waste of money to me. If you really like the Honda and Acura factory wheels better than aftermarket wheels (which you would have more money to spend on because no conversion would be neccessary), then I guess it wouldn't be a waste of money for you. Most people prefer aftermarket wheels to Honda and Acura facory wheels and there are is no shortage of aftermarket wheels that come in our stock bolt pattern. The money you would be spending to do the conversion could go towards nicer wheels that fit our 4-bolt pattern.
I'm a llama :(
Laguna CL
personally, i think a 5 lug conversion would be tight too. I was thinking if the 2000+ tl factory wheels were possible, because they look like our 5 split spoke factory wheels. If you can do it for cheap man, share the info...
2600lb CL
This is what it runs for labor alone. This does not include the cost of parts. And this is what is changed during a 4to5 lug conversion.
"Brake / Suspension Service Price EF/EG
EK/DC chassis $375
5 lug Type R / 4 lug GSR Brake Conversion
We will replace your entire Civic brake system with larger Integra counterpats. Upgrade to Integra four wheel disk brakes or the huge Type R 5 lug setup. Includes changing the Master Cylinder, brake booster, and brake porportioniong valve (as needed). Full bench bleed of M.C. and fluid flush of entire system to restore original brake performance."
the site was: http://www.hybridautomotive.com/service/
EK/DC chassis $375
Tristate ViP Crew
I'm gonna ask my super mechanic this weekend, and see what he says. This guy builds right hand drive RX-7's and all kinds of Nissans. I would love to have the factory CL Type S wheels but I really want the new Racing Harts J5 or J8 that is why I wanna do the conversion. Plus the majority of the 5 lug wheels have a deeper dish. On my civic before I went bigger I had factory GSR wheels, so I know what people mean by the factory Acura/Honda Wheels.
Gimmie my points Biatch!
Who has done a 5 lug conversion on their 2.2 and how much did it cost?
Comrade Stalin
If you can't find rims that you like that are 4-lug, then you are not looking hard enough. They make every rim design you could ever want in 4-lug. Its not like 5-lugs makes it a better wheel.
7-30-05 First Place STS!
the point of doing a brake conversion on a 2.2 is so you can have a rotor over hub configuration as opposed to the stock hub over rotor..no more need to press or hammer out the front brakes
it also gives you the freedome of running larger discs as well as swap in better calipers
if you're doing this for bling factor...you should save your money...but it's your money do what you want with it
also, i don't see how the handling and strength of the car will be effected but maybe someone can explain that to me
here's a write up..have fun
http://www.accordinglydone.com/forum...&highlight=lug
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
If anyone is looking to do this, I have a 5 lug conversion set for sale, PM me.
07 tl-s in
only reason i want to do this is my next car (cl-s or g35) will be 5-lug. get 2 sets of
![Pimp](https://acurazine.com/forums/images/smilies/pimp.gif)
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by subbuzz
no more 5-lug? y?
rims and swap them whenever i feel. but i do also feel the point 5-lug convo to get newer stock acura/honda wheels
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by Motohip
Do you have everything necessary for the coversion???
neuronbob
23
07-16-2019 10:48 AM
HondoGermany
23
01-08-2016 03:01 PM
