Whats the name of this hose??
Old Feb 12, 2017 | 11:37 PM
Gigolo's Avatar
1999 Acura CL 2.3
hello again
whats the name of this hose??i found its leaking right where it connect to that other bit.im gonna try to snip the end and reattach it till i can get another hose but i need to know the name..
out of curiosity when the engines hot can that lil hose drain the radiator completely?
thanks in advance
Old Feb 12, 2017 | 11:50 PM
CurrentDraw's Avatar
It is a coolant hose coming from the fast idle thermo valve to the thermostat housing area.
I'm pretty sure Acura parts catalog calls it a "breather heater hose"
Old Feb 12, 2017 | 11:54 PM
Gigolo's Avatar
1999 Acura CL 2.3
thanks man...
ill see if autozone or something have one in the morning
can a radiator be emptied out from that hose alone?
Old Feb 13, 2017 | 12:09 AM
It can happen if the hose has been leaking for long. I'd check the fluid in the radiator to be certain.
Old Feb 13, 2017 | 12:16 AM
Gigolo's Avatar
1999 Acura CL 2.3
just checked and it was empty or almost empty..it was full when i left earlier today..drove about 60miles roundtrip and luckily noticed the smell when i got home and checked again an hour or 2 later and saw the puddle..
than took a look and saw the hose was bad..just wondering of another hose could of drained so much fluid but im guessing its probably this lil fkr
thanx man..i should be able to do this myself
Old Feb 13, 2017 | 12:19 AM
Gigolo's Avatar
1999 Acura CL 2.3
can anybody suggest which coolant i should buy?? 50/50 or sumthn else?
Old Feb 13, 2017 | 12:40 AM
Oem Honda
