what is this?????
Old Jun 20, 2011 | 08:29 PM
99cl30NS's Avatar
what is this?????
I have been having problems with my car overheating and the temp fluctuating so I thought it might be the thermostat and changed it. That solved the problem for a while but now it seems to be leaking fluid from an area behind the engine.
I have a 3.0 if that'll help
Old Jun 21, 2011 | 06:10 AM
timeizmoney22's Avatar
What kind of fluid?
Old Jun 21, 2011 | 11:41 AM
99cl30NS's Avatar
Antifreeze
Old Jun 21, 2011 | 11:45 AM
asianspec's Avatar
check your hoses. probably needs to be replaced.
Old Jun 21, 2011 | 12:07 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
behind the engine? definitely could be a coolant line, but the main coolant lines are in the front, there's one that runs through the throttle body though.
Old Jun 21, 2011 | 12:45 PM
99cl30NS's Avatar
I changed the main ones about a month ago that's the only thing that has me confused as to what it could be.
Ill look around more once I'm home though
Old Jun 24, 2011 | 10:37 AM
99cl30NS's Avatar
So after searching for the leak I found a black box-shaped mechanism behind the engine. I removed a tube that was leading to it and it had antifrreeze in it. Does anyone know what this could possibly be
Old Jun 24, 2011 | 11:22 AM
Project_CLean's Avatar
MMkay.
water valve..
Old Jun 24, 2011 | 11:26 AM
MMkay.
should be on a small bracket;and one of the hoses should lead to fire wall? (heater unit;heater core)
Old Jun 24, 2011 | 12:02 PM
97'CL2.2's Avatar
yea there should be two medium sized rubber hoses back there..thats part of the heater core and those hoses commonly dry rot...just be thankful its not leaking from the core itself.
Old Jun 24, 2011 | 12:41 PM
MMkay.
yea; part number 79710-sv7-a01 from acura. $65 at my dealership.
Old Jun 24, 2011 | 01:21 PM
99cl30NS's Avatar
Ill see if that fixes the problem
Thanks for the help guys
Old Jun 24, 2011 | 02:45 PM
MMkay.
hit the "thanks" button
