Turn Signal short?
Turn Signal short?
So some idiot tried reinstalling my battery in backwards and got a huge spark. I then got in the car and took her for a spin to see what was wrong.
Problem: NO turn signals. Probably shorted it out? I don't get any signal when i try to switch them on. ALSO my brakes lights won't come on.
Is there any relays to check or what?
HAHAHA actually. yes. another guy i talked to was like "just say it was somebody else so you don't look like an idiot". so in defense i just wasnt paying attention ![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
but i checked ALL the fuses and none were blown. none.
AND i had another problem start the other day. Something is draining my battery while my car is off. Not a thing is left on. i can't figure out wth it is. grr!
1998 CL 3.0
Use a multi-meter to see if you're getting power to the wiring harnesses that connect the bulbs. Start tracing back from there so if the wires are damaged at least you'll know between which points. The bulbs might be destroyed even if they don't look like it on visible inspection.
The flasher relay for the turn signals is right above the interior fuse box.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
yep, 2 fuse boxes, check them both
09-17-2015 09:01 PM
Greengecko
09-16-2015 08:19 PM
