Turn signal issue
Old Dec 4, 2010 | 01:21 PM
RDZLEON's Avatar
4th Gear
Turn signal issue
Hello outhere, suddenly my turns signals death, but the hazard lights are working; i checked every thing, the relay is good, the switch is working properly, i have tested the wiring puting voltage into the switch harness and the lights working, i have checked all the fuses; but i do not know which is the turn signal fuse since the guy who sold me the car did not tell me that the fuxe box cover under the dash was missing,
please someone tell me where is located the fuse turn signal (row and column) and if the fuse is ok, what else i have to do to fix it?
Thank for your comments,
Old Dec 4, 2010 | 06:25 PM
BAGII's Avatar
What year and engine? On a '99 2.3CL, check under left kick panel, there will be auxiliary fuse holder. check fuse 12. and then check fuse 35 in the underhood fuse box.
Old Dec 5, 2010 | 01:22 PM
RDZLEON's Avatar
4th Gear
turn signal issue
Yea, i forgot to mention it, it is a 2.2. cl, 1997; may be it is the same location as ´99, 2.3 cl?
Thanks for the comments
Old Dec 5, 2010 | 04:11 PM
BAGII's Avatar
Yeah, I'm sure its the same. Let me know how it goes.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
